Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Ram Daytona
Old 01-26-2011, 08:44 AM
Rep:1824
Originally Posted by D.Rowe View Post
Guys,
Wurth product on my dorrstep last night...got up early this am and have a "spray party" on all the suggested areas plus door hinges..etc. Took my Daytona up on the highway...the noise is GONE!!!!!!!!!!!!!!!!!!! This stuff is really amazing!!!!
I probably have a few more spots to find and hit but WOW! Yes..it is expensive but it already is 100% worth it.
Is there a suggested time frame to reapply this ? every month? 3 months 6 months? I'd use it everyday if there was value.
Thanks again for the suggestions. Great product here!
I just use the stuff as needed but it won't hurt to use it more often as a preventive measure.
Old 01-26-2011, 08:45 AM
D.Rowe's Avatar
D.Rowe D.Rowe is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Rep:121
D.Rowe will become famous soon enoughD.Rowe will become famous soon enough
Question...I can't see what is really connecting into the tire/rim as far as connections nor do I know much about the details but is there any value of a blind spray behind there?
I can only turn my wheel so far so can't really see in there without having her jacked up.
Weather Tech mats, 12" Billet Antenna, Recon 60" LED bar, Spyder LED tailights, Map & Dome LED's, Pioneer AVH-P6300BT, Upgraded Tweeters in Dash, Cadence 8" Sub under Drivers Seat
Old 01-26-2011, 09:14 AM
Rep:1824
If you're talking about the ball joints and tie rod ends, theres no need to spray anything there. The boots on these links are sealed, so unless you want to pinhole the boots and spray some in there, you can leave them alone. If you get a noise from one of those joints down the road, you might try it then.
Old 01-29-2011, 08:57 AM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Squeak is back..urg...maybe i missed spraying something...will touch up a few spots again. The noise seems to appear when there are bumps in the road only...
Old 01-29-2011, 11:20 AM
Ram50Man's Avatar
Ram50Man Ram50Man is offline
Vehicle: 1989 Dodge Ram 50
Trim Level: Standard
Color: Primered Black
Rep:71
Ram50Man will become famous soon enough
That is a very good idea, im going to have to look into getting me some, i have an old truck, that is more squeak, than vroom-vroom!.... lol
'89 Dodge Ram 50: 2.0L, 5 SPD Manual, 2 WD.
Old 01-29-2011, 11:13 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
So my focus here is anything i can see in the front wheel wells with the wheel fully turned...seems to be a ton of stuff there that could benefit from a spray or two....i could have missed something so I'm chalking the noise up to me just missing something for now...more tomorrow morning when I can re-spray....really hoping I can find this because the noise is driving me nutz since I'm such a perfectionist.
What I can say is that all 4 doors open as if they were brand new now thanks to a few quick sprays in each.
Old 01-29-2011, 11:25 PM
Ram50Man's Avatar
Rep:71
If it only squeeks on bumps, you might need new shocks/struts. if you park your ride and get out and push down repeatedly on the front end, like your testing the shocks, does the squeek appear? if so, i would look into getting them adjusted if possible or replacing the bushings on the mounts for them or just replacing them entirely. I dont know much about shocks and struts though, so i dont know if they even can be adjusted.
Old 01-29-2011, 11:30 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Will try this in the am before spraying anything...good call on this..Thanks!
Old 02-08-2011, 07:40 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Default Still there!
Darn squeak is still there!!!!!!!!!!!!!!!!!!!!!!!
I lubed everything i could see in the front wheel wells. I'm wondering if this is something else now. Feel like it could be a plastic piece of the hood or a loose piece under the hood (ie. latch or something). Driving me insane!!!!!!!!!!!!!
Old 02-24-2011, 07:52 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Urg! Squeaks still there...really sounds like it's right under the hood.
Wondering what can be tightened under there now????
