Old 01-18-2011, 03:18 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Default Wheels smoked on dyno
Had my truck on a dyno today so I could dial in the speedo, turned the ESP button off but the wheels still smoked like crazy and I had to shut it down. I dont know if it was the traction control or the abs. Is there a way to shut everything off so it can be put on the dyno. Also want to add that the tire size adjustment on the DS Predator is not accruate, my tires are just over
34" and in order to get the correct MPH I ended up with a 33" setting on the Predator
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 01-18-2011, 03:43 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
IDK man i never had that issue when i did my previous 2 dyno's. Might have been the guy running the dyno incorrectly?
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 01-18-2011, 04:21 PM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
yes the rear is applying brakes, I had to deal with that issue at my local dyno shop. He confirmed it by pointing a temp. gun at rear discs. Find another shop that knows how to put your truck on dyno mode.
Old 01-19-2011, 11:39 AM
RamTex's Avatar
Color: Stone White
Rep:366
How do you put the truck into dyno mode?
Old 01-19-2011, 11:56 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
yea..it's the dyno guys..I've seen diesels with over 1k lbs tq dyno and i've never seen one squeel a dyno...
Old 01-19-2011, 12:51 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
As for the 34" vs 33" tire size, I'm curious what the tires measure when you put a tape measure to them.
Brian:
Old 01-21-2011, 04:25 PM
Ggreek5 Ggreek5 is offline
Ggreek5 is on a distinguished road
I think the ABS fuse needs to be removed in order to dyno. I had to do that on my Jeep SRT8.
Predator-K&N CAI-14in Mufflex-Black 5in Tips-20%Tint-F1 Bakflip-Smoked Tails-8000k HID's
Old 02-22-2011, 03:17 PM
rick980's Avatar
rick980 rick980 is offline
Vehicle: 2015 RAM Quad Cab Sport
rick980 is on a distinguished road
What about holding the key forward, shut down everything on mine and allows my to lay a nice patch, other wise a chirp and only on old ashphalt never on cement.
Old 02-22-2011, 04:43 PM
JTHennessey JTHennessey is offline
Rep:60
JTHennessey will become famous soon enough
Truck should dyno with the ESP off and in Manual Shift Mode... 3rd gear is what I use on mine
2009 Dodge Ram 1500 Sport 2WD
- Lowered & Supercharged
Old 02-22-2011, 07:01 PM
Greg50Lt's Avatar
Greg50Lt Greg50Lt is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
Trim Level: Sprot
Rep:20
Greg50Lt is on a distinguished road
Have you guys done any testing with the manual shift and running the truck in drive? Question is which one does better shift wise (faster and more direct) also to those who drag race which one did you run a better time with?
OE: Nav/Alpine, Backup cam, brake controller, side steps Aftermarket:Bedliner, Tonnopro bed cover, Windows 20% Tails and Cab light tinted, 18in Magnaflow, Black Fuel Hostage 20x9 trail Grapplers 295-60R20, TGC 2.5 front spacer .75 rear, Billet fuel door
