Service Park Assist - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-11-2016, 03:59 AM
Mrjunk Mrjunk is offline
Vehicle: 2011 Dodge Ram
Mrjunk is on a distinguished road
Default Service Park Assist
Edit: Truck is a 2011 dodge ram 5.7l Hemi Crew cab sport
I am coming to this community in desperation for help in fixing a problem I have been trying to fix for almost 5 days now. I have searched through google and this forum to the deepest corner and have yet to fix the solution to my problem.
When I bought this truck used from a private seller the park assist never worked. When I inspected the sensors I noticed 1 was missing so I didn't bother with it for awhile. Later down the road I bought a sensor, then I noticed that the wiring to that sensor was ripped, so 5 days ago I spent $130 on a new wiring harness for all 4 sensors assuming this would finally get my park assist working. Nope.
So I looked online where people had suggested turning the truck on and putting it in reverse with the wheels blocked, and then covering and listening to all the sensors. I did that and they are all clicking beautifully I have gone as far as buying 2 extra sensors and trying to swap them out but still no success.
I will reset the error message with the keys but every time I throw the truck into reverse I get the chime and boom, "Service Park Assist".
So I changed the fuse, still doesn't work. So I changed every fuse in an insanity plea, still doesn't work.
I tried spraying each connection with electrical cleaner and giving them good wipes. I even removed the ground cable, scrubbed it with a wire brush, and sprayed it with electrical cleaner.
I even went as far as removing the sun visor and roof panel on the passenger side to confirm that the park assist module had not been removed by the previous owner. It is still there and doesn't appear to have any corrosion!
Any help is appreciated! Please don't say go to dealer, the hemi-ticking headers, wheel bearing hub, leaking drive shaft seal, and bad 4wd transfer motor have already drained my pockets thus far
Old 07-11-2016, 10:02 AM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is offline
Super Moderator
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:883
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
I didn't think park assist became available until 2013
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 07-11-2016, 05:44 PM
You must be thinking of the front bumper park assist. This one has the rear assist only
Old 07-11-2016, 06:06 PM
Super Moderator
Rep:883
Front didn't come out until 2014; maybe it was earlier for the rear. You're sure its OEM?
Thunderhorse:
Colt:
Old 07-11-2016, 06:08 PM
I'm sure it is,
All the connections are here for it, the fuse box has the "prk assist", and the instrument panel and control settings on the dash all have the park assist on and off options...
Old 07-11-2016, 07:18 PM
Rep:2964
I have rear parking assist on my '09 Ram 1500
back then they had a small light bar with several lights on it, right in the interior by where the 3rd brake light is located
trouble shooting video, it is for a Ford, but may apply to Rams
mechanics way of doing a Ford
Old 07-11-2016, 09:10 PM
Ive tried all the steps in the above video and will be borrowing my friend's scanner this weekend to hopefully pull a code.
In the meantime ive ordered 4 new knock off sensors for ebay... maybe a new set will do the trick. Ill be back with updates..
Old 07-12-2016, 09:51 AM
Color: MAXIMUM STEEL
Rep:783
if they dont work, might be because they are not compatible with the stock system.
"service park assist system" message Oh9Ram 2009 Dodge Ram Forum 7 07-11-2015 08:36 PM
replacing park assist sensors with 14's nikeman 2013 Dodge Ram Forum 12 11-16-2014 03:39 AM
AMV sales code (Backup Camera & Park Assist group) on 2014 Canadian Big Horn - HELP! matticus 2014 Dodge Ram Forum 1 07-17-2014 05:51 PM
Park Assist Sensors ga80486 LD RAM - General Discussion 2 11-23-2013 08:33 PM
2012 ram 3500 backup camera and park assist sensors okie Electrical 1 02-19-2013 04:16 PM
