Old 01-18-2011, 11:21 PM
Ram50Man's Avatar
Ram50Man Ram50Man is offline
Vehicle: 1989 Dodge Ram 50
Trim Level: Standard
Color: Primered Black
Rep:71
Ram50Man will become famous soon enough
Default Intake Manifold
Ok Guys and Gals, another daily trivia question from yours truly.....
I want to know what the difference is between a NON-EGR Intake Manifold, and a EGR Intake Manifold is? My truck has a EGR on it, but I was wanting to replace my current intake manifold with this....
Edelbrock Intake Manifold - Endurashine Aluminum Direct OE Replacement
Universal
50-state legal; Performer RPM, Intake Manifold, Designed For Great Top End Power With Good Throttle Response, High Rise, Dual Plane, Non-EGR, 1500-6500rpm, Endurashine, Recommend FelPro Gasket Part Number 1205 For Manifold Gasket
Finish: Endurashine
Material: Aluminum
Type: Direct OE replacement
Any info would be appreciated! Thanks all!
'89 Dodge Ram 50: 2.0L, 5 SPD Manual, 2 WD.
Old 01-19-2011, 05:33 AM
mph300's Avatar
mph300 mph300 is offline
Vehicle: 2010 Laramie Crew 4x4
Color: Mineral Gray Metallic/Light Graystone Pearl Coat
Rep:41
mph300 is on a distinguished road
EGR stands for Exhaust Gas Recirculation. EGR is used for controlling emissions.
A non EGR manifold does not have provisions for mounting an EGR valve or the required EGR passages to recirculate the exhaust gasses.
Everything you want to know about EGR systems:
http://www.asashop.org/autoinc/nov97/gas.htm
The most common issues with EGR removal are:
1. higher emissions, possibly failing an emission test from a reading or visual inspection standpoint
2. detonation due to higher combustion temperatures
Mike
BTW.....I assume you have another RAM other than the one in your sig. It would be kinda hard to install the manifold depicted on your RAM 50!
Got CH3NO2?
Old 01-19-2011, 08:09 AM
Ram50Man's Avatar
Rep:71
You know, i was looking at the manifold, and i told myself there is no way that is for my truck! I hate when websites say its a direct OEM for my truck. i have been running into this problem a lot lately.
