LS Differential - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-19-2011, 03:14 PM
slikjr slikjr is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Trim Level: Sport Crew Cab
Rep:28
slikjr is on a distinguished road
Yep, a LS helps a lot in snow and on ice. The friction on these surfaces doesn't put enough torque on the diff to break a LS free, so essentially its locked. On gravel or mud, the torque/friction will break it free.
However, lil trick of the LS...don't wanna do it too often but if you're in a jam in the mud, it will help...give it some (just enough to spin the tires and break LS open) throttle then mash hard on brake pedal, give it some gas then mash hard on the brake pedal, and so on. Of course this will only help if you aren't hung up to the extent when you are at idle in drive both rear tires aren't spinning anyway ahahah. Do that quickly back and forth. Keeps the LS locked up every time you release the brake.
-Slikjr-
'11 Ram 1500 CC 4x4
Old 01-21-2011, 01:04 AM
gino2011 gino2011 is offline
gino2011 is on a distinguished road
Originally Posted by Cdncarnut View Post
Does the Sport not come standard with the 3.92 LSD?
No it's a option you can get a sport with 3.55 gears, but the dealer i went to first told me he had none since last year they did not sell to good.
Old 01-21-2011, 02:55 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Originally Posted by slikjr View Post
Where abouts is this sticker? On the diff housing or the axle itself? My "options sheet" from the dealer says "Anti-spin" rear axle. Is this what they decided to call limited slip?
My sticker is on the axle, not the diff cover. I'll just describe where I looked... I crawled under the truck, just in front of the right rear tire. Look up (toward the rear of the truck), directly at the axle, mine is right there. It's about 2"x3", white in color, and has a barcode on it. I don't know if Dodge puts them all in the same spot, but I would assume so.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
