Old 01-19-2011, 07:32 AM
donn12 donn12 is offline
Vehicle: 09 Ram
Trim Level: TRX
Rep:15
donn12 is on a distinguished road
Default 17" TRX wheel / tire help (w/pic)
How wide are the factory wheels? I am thinking about going up from a 275/70r17 to a 295/70r17. I think this wheel will be wide enough but I dont know if I need different wheels for offset to clear the suspension. It also looks like BFG or maybe terra grapplers are the only tires I see in this size but the BFGs seem to get great ratings. If I do need wheels I probably have to go to an 18" wheel. I want tires at least an inch taller and +/- 1 inch wider but I don't want to hurt my handling too much especially in the rain. One thing I know for sure is that the factory wheel and tire setup looks weak and I am not crazy about most of the aftermarket wheels that I see.
Old 01-19-2011, 09:38 PM
MOPAR MULiSHA's Avatar
MOPAR MULiSHA MOPAR MULiSHA is offline
Vehicle: 2012 Dodge Ram 1500
Color: Sage Brush Pearlcoat
Rep:219
MOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura about
I have 295/70/17 Terra Grapplers on stock 17's and only rub at full lock, my stock 17's are 17X8. Look at your door jam where your paintcode is and it'll actually tell you the stats on the wheels (17X8, 17X9....etc)
2012 Sage Brush Pearlcoat Ram 1500 Big Horn Crew Cab Hemi 4x4 w/ Ram Box Storage System
Old 01-19-2011, 09:46 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
How much wear on your current tires? I'm in the market for some 275/70/17s and I'm in VA.
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 01-20-2011, 10:02 AM
Vehicle: 09 Ram
Trim Level: TRX
Rep:15
Tolleyman I dont think I am going to get rid of the stock tires but if I do I will let you know.
Old 01-27-2011, 07:11 PM
Currdog87 Currdog87 is offline
Vehicle: 2009 Dodge Ram
Trim Level: TRX4
Currdog87 is on a distinguished road
I have a set of 275/70/R17 Goodyear Wrangler At/s with 10,500 miles on them that I am willing to sell.
Old 01-27-2011, 08:10 PM
Going to the 295 section width tire won't be a problem. Your stock wheel can handle that. Once you get to 305 and above I'd be concerned about it popping off the rim due to a good jolt or bounce.
You are only going up 20mm with the 295 which is .787401"
Old 01-27-2011, 09:02 PM
Color: Gold/Silver
Currdog87, PM"d ya.
Old 02-07-2011, 08:52 PM
Trim Level: TRX4
Sorry About that, I cant respond to the PM because I have not had enough posts yet. And then I couldnt find my way back to this thread.
Old 02-08-2011, 06:54 AM
Color: Gold/Silver
You can email me at tolleyfamily@verizon.net
thanks.
