Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 01-19-2011, 09:16 AM
longbow longbow is offline
Vehicle: 2012 Dodge Ram 1500
Color: Molton Red and Silver
Rep:37
longbow is on a distinguished road
Default Need to remove the driver side door Panel??
I've got to replace my driver side mirror ( seems the door garage door shrunk).
Anyways purchased the part through Discount Auto Mirrors , and appears OEM.
I need to take off the door panel to get at the wiring harness.
Does anyone have the how to get the panel off ??
I see a few screws , but not sure about the door handle etc .
Old 01-19-2011, 09:19 AM
Rep:1885
REMOVAL
NOTE: Rear door switch shown, front doors are similar.
1.Using trim stick C-4755 or equivalent, release the door switch/bezel (1) from the door trim and disconnect the electrical connectors (2), if equipped.
2.If equipped, remove the manual window crank (1) using a window crank removal tool (2).
3.Using trim stick C-4755 or equivalent, remove the mirror flag (4).
4.Remove the screw (2) and remove the interior handle bezel (3).
5.Release the plastic push pins (1).
6.Raise the trim panel (6) upward far enough to disengage the hooks on the back of the panel from the inner door and the door lock knob from the top of the panel.
Old 01-19-2011, 09:35 AM
JwilsYellowRam's Avatar
JwilsYellowRam JwilsYellowRam is offline
Vehicle: 2008 Dodge Ram 1500 Sport
Color: Yellow
Rep:61
JwilsYellowRam will become famous soon enough
And that's why I joined this forum! Awesome job Ramtech! Need more people like you around!
Stainless CAI, Cherrybomb glasspack muffler dumped over rear axle, Superchips 3865 Programmer, Debadged, Black grill inserts, 2" rearend drop, yellow HID headlights and foglights
Old 01-19-2011, 09:40 AM
Color: Yellow
Rep:61
And this is why I joined this forum! Because of people like this! Awesome job RamTech!
Old 01-19-2011, 09:42 AM
Rep:37
Thanks Ram Ram Tech !!!
Old 06-02-2013, 08:54 AM
Krimass Krimass is offline
Vehicle: 2002 Dodge ram
Trim Level: ?
Color: Burgundy
Krimass is on a distinguished road
Default Door panel removal 02 dodge ram
I am having the same issues on my 02 ram im nit very good with the sizing of bolts but i was curious if the t30 torx driver is there other sizes for the t30 ? I need it or maybe i dont lol just wanted to make sure i have correct size on removing door panel
Old 08-01-2013, 04:50 AM
jjjmcconnell jjjmcconnell is offline
Vehicle: 2009 RAM 1500 4X4
jjjmcconnell is on a distinguished road
How do I remove the black piece behind door panel with power Windows
