Old 01-19-2011, 09:56 AM
TankGod78's Avatar
TankGod78 TankGod78 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Blue
Rep:152
TankGod78 has a spectacular aura aboutTankGod78 has a spectacular aura about
Send a message via MSN to TankGod78
Default Idle Control Valve Issue
I had a check engine light on the other day. I took it to Autozone and they said it was an Idle Control Valve. So I replaced it ($72.00 WOW). Then I also unhooked the battery to reset the check engine light. The light went out but it still Idles at 1800 RPM's. This is killing my gas. Please help me out if anyone knows what to do.
"Marines never reteat, we just fight in a different direction"
Old 01-19-2011, 09:58 AM
Rep:1909
Check and make sure you don't have any vacuum leaks. If that doesn't help, it's probably time to scan the PCM and see what the IAC counts are. Typically, you should see counts of 35 or less.
Old 01-19-2011, 10:05 AM
TankGod78's Avatar
Color: Blue
Rep:152
I do not know how to check for a vacum leak nor do I know what a PCM is. Sorry, this is my first Dodge Ram and not that smart with engines unless I have owned it for a while. Please explain or send a link that explains. Thanks for your help.
