Old 01-19-2011, 12:37 PM
mlc317 mlc317 is offline
Trim Level: Slt Quad Cab
Color: Brillant Black
Rep:16
mlc317 is on a distinguished road
Default Rim change/computer flash
Hey everybody i recently upgraded my stock 17 inch rims to aftermarket 20 inch rims. I was wondering if you have to get the computer reflashed because of the size difference. I asked my service guy before i changed the rims and he said you didn't really need to, he said the size difference would only affect the speeddomoter. Is this true, any help would be greatly appreciated.
Old 01-19-2011, 12:39 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
The dealer can change it so your speedometer is accurate. Whats the difference in overall height? including the tires, if nothing chagned there I wouldn't worry about it
Old 01-19-2011, 12:56 PM
Rep:16
Well the truck with the 17 inch rims i upgraded to the 20 x 9's and i kept the factory size for the twenty's that dodge uses on the trucks, so basically i went with the stock setup for the truck if it came with the twenty's.
Old 01-19-2011, 01:17 PM
Rep:1845
You still need to have the upgraded size programmed. It's easy to do and only takes a few minutes.
Old 01-19-2011, 01:47 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
If the tire size stayed the same the speedometer won't be affected by the size of rim.
Example: 275/60/17 and 275/60/20 are the same size tire, just different wheel/rim size so they will still spin at the same speed.
Brian:
Old 01-19-2011, 01:50 PM
Rep:16
If you don't have the computer reflashed can it do any damage to the truck in any way!!
Old 01-20-2011, 09:32 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Whats your old and new tire sizes?
Old 01-20-2011, 09:38 AM
rinkerman rinkerman is offline
Vehicle: 2010 Crew Cab
rinkerman is on a distinguished road
Rootbeer's answer that a 275/60/17 & 275/60/20 would be the same overall size is wrong. A 275/60/17 would have 693 revs per mile while a 275/60/20 would be 630 revs per mile. The difference would be big enough to require the computer to be reflashed. If you have a tuner you could change your self.
You find a 20" tire that would be the same size. A 275/45/20 would have 697 revs per mile - close enough.
http://www.tirerack.com/tires/tires....=yes&tab=Specs
