Old 01-19-2011, 12:09 PM
slikjr slikjr is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Trim Level: Sport Crew Cab
Rep:28
slikjr is on a distinguished road
Default Trailer Wiring
Simple enough question to get the answer to myself you would think...however when it's -30, I don't want to ahaha.
Is the trailer wiring (two black flaps on the back bumper), both the 4 and 7 pin, hooked up? I have heard rumour they put the plugs on there but don't actually wire them in from factory.
My Sport didn't come with a hitch receiver on it. I had to put it on. Haven't pulled anything yet and don't want to freeze needlessly hooking my trailer up to test it.
-Slikjr-
'11 Ram 1500 CC 4x4
Old 01-19-2011, 12:16 PM
Rep:1890
If the plugs are present, they should be hooked up and functional.
Old 01-19-2011, 12:25 PM
Rep:28
I would have to agree. Just a rumour I heard. Thanks for the feedback.
-Slikjr-
'11 Ram 1500 CC 4x4
Old 01-19-2011, 12:39 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
You should be able to bend down and run your hand up behind the bumper and feel the wires without laying on the ground.
But like Ramtech said, if the plugs are there, they should be hooked up.
Brian:
Old 01-19-2011, 12:50 PM
Rep:28
Yep reached under and there are wires hooked to plugs running away. I know there are wiring harnesses that hook up at the rear lights so just making sure it wasn't a case of have wiring leaving but then the other end of it that I can't see/feel is dead.
I'm sure it works. I can't see Dodge doing that (even though they don't put tow hooks on ahaha)
-Slikjr-
'11 Ram 1500 CC 4x4
