Old 01-19-2011, 02:34 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Default TPMS Question - Ramtech?
Was talking with the Tire and Wheel folks at a local dealer about cost to swap out TPMS and wheels if I decide to get new wheels but keep stock tires.
They raised an interesting issue I had not heard of and could use some verification/clarification.
They said if I were to put new tires on and the load range was different from stock or the max psi was different then the sensors would trigger a warning light/code.
They also said there are no optional sensors with different settings and the computer setting cannot be changed.
Does this make sense?
Brian:
Old 01-19-2011, 02:53 PM
Rep:1877
These tire and wheel people seem to just enough to cause confusion. Keeping in mind that tires are inflated to what's on the placard on the drivers door and not to the max pressure on the tires sidewall, going up a load range doesn't matter because you'll still run the same pressure in the tires.
Old 01-19-2011, 02:56 PM
Color: RootBeer
Rep:1287
So load range does matter though? I thought the TPMS just read tire pressure and that's all that mattered.
I use a hand-held gauge for accuracy anyway.
Brian:
Old 01-19-2011, 03:24 PM
Rep:1877
No, load range doesn't matter to the TPMS but it does matter if you were to try to go to a lower load range than what your truck calls for. It could overload the tires and cause a blowout.
Old 01-19-2011, 03:29 PM
Color: RootBeer
Rep:1287
Thanks Randy.
Brian:
Old 01-19-2011, 04:41 PM
Rep:2625
TPMS information
I have read people wondering about TPMS in here & other forums, i know less than most it would seem. I read over & over again how some people swear by ORANGE TPMS, so i googled it & now i still don't know much, but, i am more edjumicated
http://www.orangetpmsusa.com/
I didn't see our RAMs in the application lists, but, possibly we fall under the JEEP section?
http://www.chryslertpms.com/?gclid=C...FQRvbAodfC4sIw
TODAY is NATIONAL POPCORN DAY !!!!
Old 01-21-2011, 11:13 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
i went from 20's to 17's
from 33's to 34's
from 35 psi to 50 psi using the factory sensors and have not had the first issue.
i dont think it matters going up in psi only dropping psi!! could be wrong but that is what i was told!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
