Old 01-20-2011, 09:34 AM
hemidoc's Avatar
hemidoc hemidoc is offline
Vehicle: 2003 Dodge Ram 4x4
Color: Blue
hemidoc is on a distinguished road
Default Removing cataylitic converter ?
Planning on removing the converter, my question is will this mess up the computor? Will I have to reset any sensors or anything else? I know I will have to weld a bung in the pipe for the sensor at the converter. I f anyone can give me some tips or any advice it will greatly be appreciated.
Running 3" pipe back to 3"dual tailpipes, no muffler but will have resonator tips on the end of the pipes.
Thanks for any help!
Hemidoc
Old 01-20-2011, 09:58 AM
socket462 socket462 is offline
Vehicle: 2007 Dodge Ram Hemi 4x4 Quad
Color: Mineral Gray
socket462 is on a distinguished road
Hoping someone gives more detailed info.. but from how I understand it, removing the cat would mess up the o2 sensors readings (upstream to downstream) and could result in worse fuel mileage and driveability. The computer uses the results of those sensors to configure the air/fuel ratio's.
'07 1500 SLT - 4x4 QC Hemi Big Horn package- Billstein 5100's, Cooper At3's (NEW!), K&N drop-in
Old 01-20-2011, 10:18 AM
hemidoc's Avatar
Color: Blue
Thanks for the imput, I was told it would increase power and fuel mileage by removing it. I 've heard of people doing it but not sure what has to be done to keep everything running good.
Old 01-20-2011, 10:19 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Just swap them for high flow cats if you really want to, I don't think it will make that much difference. I was told mine are fine until going for boost. You will get a check engine light though. Some tuners can fix it.
Old 01-20-2011, 10:37 AM
Walmartsocialclub's Avatar
Walmartsocialclub Walmartsocialclub is offline
Vehicle: 2005 dodge ram
Rep:48
Walmartsocialclub is on a distinguished road
no man you dont wanna do that just leave your cats on and get true dual like i did and dont put any mufflers on. I got good HP and torque and mine has that low deep pitch that sounds bad to the bone. without your cats not only will you get ticketed but you have that annoying popping noise also... yeah it will be a little louder but trust me people will do more laughing then aweing when they hear it backfire
Yeh thats right i said HEMI
Old 01-20-2011, 11:02 AM
Rep:1877
Keeping in mind that you need a small amount of backpressure to help the engine make torque (what's needed most from a truck engine), I think you'll discover that the headaches involved will outweigh any benefit you might gain on the top end of the RPM curve. As for the 02 sensors, the upstream sensor is the only one used in the fuel curve calculation. The downstream sensor is used to monitor converter efficiency. Installing a free flow muffler and duals will get you the most benefit for the least effort.
Old 01-20-2011, 11:11 AM
hemidoc's Avatar
Color: Blue
Thanks Ramtech and everyone else
Yea sounds like I am opening up a can of worms that would be a big headache.
So if I run 3" pipe back from the cat with no muffler, split off into duals at the rear w/3" tips w/resonators how do you all think this will work?
The kit comes from LMC Dodge trucks
Old 01-20-2011, 11:16 AM
Rep:48
I have 2.5" but three will be fine.
without true duals i would go with 3"
with true i would go 2.5
Old 01-20-2011, 11:17 AM
Rep:1877
It should work just fine if that's the sound you're looking for. Anything done after the downstream sensor won't be seen by the PCM.
Old 02-15-2011, 02:35 AM
THasse THasse is offline
Vehicle: 2012 Ram 1500
Color: Dark Red
Rep:44
THasse is on a distinguished road
All I did with mine was cut the resonator off and it gives it a little bit deeper sound, just not much louder at all, which is kinda what I'm lookin for. I wouldn't cut off the cat, cuz it'd be a computer headache as was mentioned but the muffler and resonator can go... I'm considering just putting on a higher flow muffler and leaving off the resonator. The resonator is what gives it a higher, more appealing (apparently), exhaust tone. It doesn't seem to restrict flow much. If you remove the muffler completely you'll get more of the back cackle, something I'm trying to avoid, just fyi... It's all in what you're lookin for...
Mods: Deleted Resonator, painted talgate logo, DiabloSport tune, K&N drop in. Plenty more on the way, finances permitting...
