Old 01-20-2011, 01:45 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Well, I tried. Have you tried the winter blades from places like Autozone etc? I've always had good results with those in places with bad winter weather.
Brian:
Old 01-20-2011, 02:16 PM
AKFossil's Avatar
AKFossil AKFossil is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Inferno Red
Rep:57
AKFossil will become famous soon enough
My only issue is that for some reason right in the drivers line of sight is where the wiper fails... not on the passenger side just driver side during icing conditions.
2010 Dodge Crew Cab Inferno Red: HID Low Beams & Fog Lights 6000K, LED Interior Lights, LED License Plate Lights, Black Nerf Bars, AVS Bug & Window Deflectors, K&N Drop In Filter, WeatherTech Floor Mats, Goodyear Wrangler Silent Armors, MagnaFlow Muffler
Thinking about: New Wheels, and leveling kit.
Old 01-20-2011, 02:39 PM
jojo13 jojo13 is offline
Vehicle: 2010 dodge ram
Color: inferno red
jojo13 is on a distinguished road
I had the same issue, I replace them with Canadian tire reflex / rain x wipers, it’s a lot better but still not perfect, I think when driving the wiper sits lower than the heat that touches the windshield, causing them to freeze.
Old 01-20-2011, 03:26 PM
Tanker67's Avatar
Tanker67 Tanker67 is offline
Vehicle: 2010 Dodge Ram 4x4 QC
Color: Mineral gray
Tanker67 is on a distinguished road
You can thank a guy named Murphy for that.
Old 01-20-2011, 03:32 PM
Tanker67's Avatar
Color: Mineral gray
Thanks for the suggestions Rootbeer! I'm going to try AutoZone for a winter blade and hopefully that helps. If that doesn't do it my next step will be to kick out the windshield so when I turn on the wipers they won't smear or have any missed spots.
Old 01-20-2011, 04:16 PM
Juice420's Avatar
Juice420 Juice420 is offline
Vehicle: 2010 RAM 1500 SLT C.C.
Color: Brilliant Black Pearlcoat
Rep:946
Juice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to behold
That could be a chilly drive.
Justin
Black Mamba- Flowmaster 40 series, Airaid CAI, 20% tint, GTO taillight covers, ATA nerfs, AVS in-channel ventvisors, Curt hitch receiver, Extang Revolution Tonneau, EZ-down tailgate damper, Recon smoked 3rd brake light, Custom painted engine cover
Black Mamba's Thread
Old 01-20-2011, 04:56 PM
2010 trx4 hemi power's Avatar
2010 trx4 hemi power 2010 trx4 hemi power is offline
Vehicle: 2010 RAM
Trim Level: TRX4 Quad Cab
Color: Charcoal Metalic
2010 trx4 hemi power is on a distinguished road
My 2010 TRX4 does the same exact thing. Very annoying, and when its warm and just raining the wipers are noisy on the glass
Old 01-20-2011, 05:13 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Well mine do this as well and I have already put the new Reflex / Rain X blades on. It's not as bad as what the OP described however it is a bit annoying. I had to get out and snap the blades a few times and they were better but not perfect. This also only seems to happen below freezing.
Old 01-20-2011, 05:16 PM
sgthwy sgthwy is offline
Vehicle: 2010 DODGE RAM TRX
Trim Level: TRX
Color: BLACK
sgthwy is on a distinguished road
Its unfortunate to see someone else with the same problem. Everytime its gets below 20 here in NY with a little snow I have no view. The wipers only catch the top of the wiper blade area, leaving the center blurry and snow covered. I also have to stop and wipe the blades clean often. The truck is gararged and It doesnt happen when the temps are warmer, only when it gets fridget. Going to try the more expensive winter blades.
Old 01-20-2011, 06:05 PM
Rep:2657
i googled windshields in winter conditions & saw this
Washer Fluid Spray Bottle for Ice Free Windows
Date: 02/18/2010 Topic: Cars > Winter Driving
Living in a very cold climate I found this to be a very useful tool for winter days. Purchase a gallon jug of the re-fill windshield washer fluid and fill a small spray bottle with the liquid. When your windshield is iced over spray beginning at the top of the windshield and work down towards the midway point.
As I recall the jug directions say that this can be harmful to paint finishes, so be careful and use sparingly. This starts a melting process and the top area will loosen up by time you get to the other side of your car.
One year I gave little bottles of it to my staff and they were rather doubtful. When the staff actually used it, they reported back that it truly works a miracle!
Homemade Windshield Washer Fluid
Tip: Washer Fluid Spray Bottle for Ice Free Windows
Archived on 02/18/2010
When filling my windshield washer fluid for winter, I save some of the solvent and put it in an old squirt bottle. In the evening I spray my windows and mirrors, and in the morning the ice has never built up.
When warming your car up, it is great to have sprayed the outside of the windows first. It really helps the defroster clear the windows much quicker.
Frost-Free Windshields
Vinegar will help keep windshields ice and frost free. When a car has to be left outside overnight in the winter, coat the windshields with a solution of 3 parts White Distilled Vinegar to 1 part water.A good tip for frost free windshields is believe it or not shaving cream.rub it in good and wipe off when starts to fog up reapply.You can also use the above tip with alcohol instead of vinegar I like the green kind best.
try shaving foam on your bathroom mirror to stop it from fogging up, works great!!
http://www.ehow.com/way_5845346_home...her-fluid.html
Lift the Ice off the Window with this Homemade Deicer
You can use a household spray bottle for this. Mix a bottle of isopropyl alcohol (70% is best but 50% also works) and a few drops of dish liquid. Spray the windshield liberally, and in a few minutes, the ice lifts off the window. Also, try putting isopropyl alcohol in the washer fluid container (half fluid and half alcohol) to keep your wiper lines from freezing up in the winter.
when you pick up the winter windshield wipers, don't forget the
Rain X/Winter De-Icer windshield washer fluid
Part Number:
RX68106
good thing winter does not last all year long
2010 dodge ram, recall, safety, windshield, wipers
