Old 01-20-2011, 07:35 PM
firerescuedodge23's Avatar
firerescuedodge23 firerescuedodge23 is offline
Vehicle: 2007 Dodge Ram1500
Trim Level: SLT (ThunderRoad)
Color: Gold
Rep:59
firerescuedodge23 will become famous soon enough
Default Suspension and rim question.
I'm looking to maybe do a 4.5 lift on my 07 ram1500 2wd. http://www.performance4trucks.com/Li...pn=SKYD501MK-H
now my question is this. I have the stock 20 in rims on my ram, this kit says that the wheel size is 15-16x10. Does this mean that I will be unable to use my stock rims. I was hoping to be able to lift it keep my stock rims and but some Nitto A/T 33's on it. Is this possible?
AFE Stage 1 intake, Flowmaster 40 series exhaust, Fabtech 6 inch lift, 3 inch PA body lift, 35x12.5x20 Federal Couragia M/t, Full audio system, LSD, HIDs, Superchips Cortex, 20x10 XD Strike -24 offset
Old 01-20-2011, 07:43 PM
Yes, you can use your stock wheels.
Old 01-20-2011, 07:45 PM
Color: Gold
Rep:59
alright cool thanks just so i have the knowledge, what did that whole wheel 15-16 thing mean?
Also what would you recommend my tire size be? Its a 2wd so im not looking to do any crazy mudding just a more aggressive stance. I was going to try and run 33' maybe but what would you say?
Old 01-20-2011, 07:48 PM
You can do a 33" tall tire with this lift easily enough. My concern is going too wide, i.e. to a 12.5" or wider tire as with the stock rim offset, you may rub on the inside. A 285 or 305 section width tire would be the max.
I think they are referring to the max wheel size in a 15" or 16" diameter wheel would be a 10" wide whee. Your stock rims aren't 10" wide so you are good.
Old 01-20-2011, 08:42 PM
Color: Gold
Rep:59
another question hope you can help with this as well. I was looking at these tires http://www.performance4trucks.com/Ti...GEN15478240000
but i see for some reason it says 305/50r/20....whats with the 305? is it a typo maybe for 30.5 or is 305 a size?
Old 01-20-2011, 08:54 PM
"305" is the tire section width in millimeters. That equals 12.0078 inches.
Here's a great website that explains tire size designations:
http://www.ehow.com/facts_5801749_do...r16-mean_.html
Old 01-20-2011, 09:06 PM
Color: Gold
Rep:59
got it, its a 32' tire with 12 inch width. thanks alot for all the help
