Old 01-20-2011, 11:15 PM
Hawkinsgold Hawkinsgold is offline
Vehicle: 2011 Ram 1500 crew
Trim Level: Sport 4x4
Hawkinsgold is on a distinguished road
Default Rear Heat.
I have the center console and shifter in my 2011 sport 1500. at the back of the console there are two air deflectors and underneath both bucket seats there are air deflectors on the floor toward the rear. I have tried the heat control in all positions and I only get a trickle of air from all these rear seat deflectors. In my 2007 2500 diesel mega cab, the rear deflector at the back of the console is almost as forceful as the front dash deflectors. Has any one else had this problem with their 2011 Ram 1500?
Thanks/ Les..
Old 01-21-2011, 12:23 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
This problem was recently posted in the 2009 forum. It seems like everyone is having this problem. I guess it's a design flaw. Those vents are connected to the center vents in the front. If you close the front center vents the flow from the console will increase. I haven't asked about the problem but it seems like a poor design.
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 01-21-2011, 12:37 AM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
i havent noticed this myself, but i also havent sat in the back seat of my own truck yet :P lol but it does sound like a design problem
DODGE the father RAM the daughter!
Old 01-21-2011, 03:15 AM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
I have the same problem. The heat in the front is great, but in the back it really sucks. When my truck went in for the HVAC Recall i thought this might be one of the issues, but apparently not.
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 01-22-2011, 01:25 AM
MSPTNY02's Avatar
MSPTNY02 MSPTNY02 is offline
Vehicle: 2010 Ram 1500
Color: Mango
Rep:14
MSPTNY02 is on a distinguished road
thankful for remote start
Old 01-22-2011, 03:15 PM
Rep:2657
because i am the only person in my Ram, i can't answer your query
But, if you think about it, water & air flow work the same way
both take the path of least resistance
both are powered by pump or fan
if you take one hose & you T or Y off of it, you cut the flow by at least 1/2 & if you T or Y off of it again, then there is no force at the outlets that are furthest from the source
so you need to restrict the flow at the dash, to still have force at the furthest point
with water you can do this by starting with a 4" pipe something like a 1/4 mile long, then drop to a 3" pipe for another 1/4 mile, then a 2" pipe etc. down to a 1/2" line something like 2 miles away, to keep the same force as at the source, of coarse you lose volume all along the way
There is a formula that landscapers use when setting sprinklers on larger lawns, golf courses, cemeteries, etc.
Chrysler engineers cant' heat 50 square feet with the small fan that they use, so you have to restrict your front vents, & it helps to crack a rear window just a bit.
when trying to cool off the cab, i recirculate & crack a front window to let the hot air escape
you have to preset your climate controls when you park for the day/night if you want the cab to be comfortable when you use the FOB to start your vehicle, while you make your coffee & put on your shoes
I am finished rambling
