Old 01-21-2011, 08:15 AM
95ramstang02 95ramstang02 is offline
Vehicle: 1995 dodge ram 1500 SLTLaramie
Trim Level: SLT Laramie
95ramstang02 is on a distinguished road
Default ram failure
so i was wondering if this has happened to any one else but my truck was making a humming noise when i would let off the gas and it happened for two days finally last night the whole drive shaft fell out and was laying on the ground in the street the nut on the back end came out im pretty sure let me know if this has happened to u and what u did to fix it
Old 01-21-2011, 09:20 AM
Rep:1909
You mean the pinion nut?
Old 01-22-2011, 09:10 AM
Yea thee ring and pinion also shattered
Old 01-22-2011, 09:30 AM
Rep:1909
At the very least, you're going to need a ring and pinion set plus the related bearings and seals required for installation. There's also the possibility of differential, carrier and housing damage as well. The first thing to do is have the damage assessed.
Old 01-23-2011, 02:42 PM
Not good . I've seen this happen before . You may be better off tracking down a used unit in a salvage yard .
Old 01-24-2011, 09:51 PM
so it was 900 to get a new reing and pinion and seal replaced i almost cried when i saw the billmoral of the story dont let some one you dont know work on your truck because they will use the same pinion nut twice and that just doesnt work
Old 01-24-2011, 11:03 PM
oh wow...that really sucks!
