Airram Power wire and Superchips? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 01-21-2011, 02:09 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
Default Airram Power wire and Superchips?
Any benefits to using the Power Wire from Air Ram if I'm already using a Superchips tuner? I suspect the tuner already make a similar change. Anyone know, perhaps had first hand experience.
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 01-22-2011, 12:17 PM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
I would not use the power wire at all. I don't knwo that product in particular ... but almost every device of that type and description is just an in line resistor that tricks the computer into adding more fuel to the mix. Now I read the description on their website and it claims they don't do that, then describe the result as lower the temp read by 20 degrees ... which will do exactly what I described.
You might get a slight performance boost over the stock tune (since they are correct that stock tune on most vehichles is slightly lean to help reduce emmisions) but at the cost of injecting more fuel than nessasary. A good tuner should give you an omptimal ratio ... and I would not mess with it. This type of device is a well known gimic that has been around for years. If it worked you would hear a lot more about it from true performance buffs. If you are getting a superchips I would NOT also get the Power Wire as it may cause the system to run too rich and ultimately reduce performance.
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 01-22-2011, 02:47 PM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
i have both. i had the power wire for a few years and didn't notice any difference - the superchips tune has been in the truck for 7 months and i love it. i had to detune it to get some work done on the truck and it was real noticeable how much of a difference it makes.
