Old 01-21-2011, 08:42 PM
j2roch's Avatar
j2roch j2roch is offline
Vehicle: 2006 Ram 1500 4x4 Sport
Rep:52
j2roch will become famous soon enough
Default Stereo Deck Installation Questions
I'm in the middle of installing my Pioneer AVH-P5200BT in 06 Sport Quad Cab. The factory deck I just removed (4 speaker system, non-navigation) had Sirius Satellite within the unit. There is a antenna on the top back of cab which I presume is for the Sirius. Does anyone know which wire i can splice into, to utilize this antenna? Also, my factory had Bluetooth. Do I need to run a seperate mic for the new Bluetooth module or can I use the the existing one where ever it might be?
thanks,
J2roch
Old 01-21-2011, 10:47 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
i was told i had to use a different antenna!!
if the radio doesnt have the mic built in i would think you will have to have one for that specific radio? not sure tho!!!!
someone will give you a better answer soon!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 01-22-2011, 09:47 PM
j2roch's Avatar
Rep:52
Finished install today! You CAN use the existing Sirius antenna. My factory tuner was located just above my glove box. The wire is black with a yellow/gold color plastic clip to fasten to tuner. Remove the clip and there you are.
