just a thought - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 01-21-2011, 09:26 PM
67Polara's Avatar
67Polara 67Polara is offline
Vehicle: 2001 2500 ext cab long bed
Trim Level: sport
Rep:77
67Polara will become famous soon enough
Default just a thought
would it be possible to make a my ram twin turbo or single turbo ?
if it is, what would go into doing that ?
"I'm your huckleberry" (Doc Holiday)
Old 01-21-2011, 11:17 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I can't see why you wouldn't be able to do either. Just need to do a lot of research into which kits are best for your application.
Keep in mind turbo gives high end power whereas a super charger gives power off the line.
Brian:
Old 01-21-2011, 11:33 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Autobred knows of a twin kit in the works, single remote setup would be easy too. Patience is key, from what I've heard so far!
Old 01-21-2011, 11:46 PM
It's all in how much you have to spend .
Old 01-21-2011, 11:48 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
yeah when you look at doing turbos, you will also have to look at cams, injectors and possibly a new tranny if you go with a twin. a new rear end may be in store as well
DODGE the father RAM the daughter!
Old 01-24-2011, 02:29 AM
67Polara's Avatar
Trim Level: sport
Rep:77
hmm... maybe rootbeer has the right idea with the super charger, would i still need to look into working with the trand and rear with a spuer charger ?
Old 01-24-2011, 07:35 PM
nate8604's Avatar
nate8604 nate8604 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLT/Big Horn
Rep:36
nate8604 is on a distinguished road
Lots of $$$. If you go to shophemi.com I saw some turbo and super charger kits on there, but they didn't come cheap.
Old 02-15-2011, 02:28 AM
THasse THasse is offline
Vehicle: 2012 Ram 1500
Color: Dark Red
Rep:44
THasse is on a distinguished road
If you want the turbo or supercharger you will likely need to beef up any part of the truck that utilizes the power created i.e. transmission clutches, rear end, etc. Horsepower is useless if you don't have the parts to put the power under the tires. With twin turbos you would generate enough power to slip the clutches in your tranny and possibly strip gears in your rear. You would need to talk to somebody smarter than me to find out how much "beef" you need to add though...
Mods: Deleted Resonator, painted talgate logo, DiabloSport tune, K&N drop in. Plenty more on the way, finances permitting...
