Place your Ad Here!
Old 01-22-2011, 01:08 AM
ram8923 ram8923 is offline
ram8923 is on a distinguished road
Default question about 18 in rims
Im looking to put 18 in rims on my stock 2004 quad cab 5.7l.
The rims are 18 X 9 rockstar rims with a 0mm offset and and 5.00 backspacing
The tires are 285/60/18
http://cgi.ebay.com/ebaymotors/XD-RO...ht_3048wt_1165
are these going to fit? i know the seller says they will fit but i just want to make sure because people will say anything to sell something.
Old 01-22-2011, 01:16 AM
Rep:1625
I don't see a problem with that setup at all, shouldn't be any rubbing.
Old 01-22-2011, 04:02 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
So they're 31.4 inches tall and 11.50 inches wide. Totally fine. The stock 265s are not much smaller.
Old 01-22-2011, 04:25 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
They will fit. I have 18's on my truck... Just know that your factory wheel is about a +25 offset so the 0 offset will probably make the wheel and tire stick out just a tad, not bad, but definitely more than stock. I have a +10 offset and 275/70/18's and my tire sidewall is pretty much even with the wheel well side.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 01-22-2011, 04:26 PM
im fine if they stick out a little bit i actually like the look of that. but i just wanted to make sure i wasn't going to have any problems getting them to fit on the truck. because when i bought rims for my charger they were a +35 offset and needed to be +24 so i had to get a spacer to stop the, from rubbing on the control arm. i dont want to have to do that with the truck and thats why i was asking.
Old 01-22-2011, 04:33 PM
Just a comparison for ya...
KMC XD Addict 18X9, +18mm offset, 285/75R Toyo AT tires.
Old 01-22-2011, 04:39 PM
ok and mine should stick out 18mm more with a 0mm offset right?
Old 01-22-2011, 04:46 PM
Here's a good site that explains offset, backspacing and other wheel technical info:
https://www.rsracing.com/tech-wheel.html
Old 01-23-2011, 05:43 PM
ok. thanks for the info. it sounds like they should fit if i understood everything correctly.
Old 02-01-2011, 09:46 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Rockstars?!?!?! Eww!!!!!
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
