Old 01-22-2011, 10:58 AM
LukeSSmith81 LukeSSmith81 is offline
Vehicle: 2007 Ram 4.7 SLT 4x4
Trim Level: SLT Big Horn
LukeSSmith81 is on a distinguished road
Default Cat problem I think P0430
My CEL came on the other day when it was snowing and I drove home in 4wd at about 50mph. I had checked and it was p0430. It said cat efficaincy low bank 2. Possible causes were missfire which I just put new plugs in 3 weeks ago, bad cat convertor, large vacuum leak or oil leaking into rings. I have noticed a rough idle when its cold out when first started. I have had the truck for 3 months and it seems to be fine maybe a loss of power on freeway but that might just be the 4.7. If it is the Cat I have heard by law you get a 8 yr 80mile warrenty on them. In the manual it says 5yr 50k. Does anyone know which is correct and any ideas on problem.
Old 01-22-2011, 12:25 PM
Valve's Avatar
Valve Valve is offline
Vehicle: 2005 Dodge Ram 1500 Quad 4x4
Rep:141
Valve will become famous soon enoughValve will become famous soon enough
possibly a O2 sensor.
Not sure on law for cat's warranty.
Line-X : Extang : Python 990 SSLCD : Tailgate Lock with Doors :
Fog Light Toggle Bypass : AeroTurbine at3030 : Tint match rear QC : SilentArmors on stock 20s(nitto and wheels in Future)
2005 Dodge Ram Service Manual
Old 01-22-2011, 01:48 PM
Rep:1885
Most likely the converter is failing. Your extended federal emissions warranty should cover the repair.
Old 01-22-2011, 04:39 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
Thats the rear 02 sensor code, it's ether the sensor or the cat. Check the connection.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 01-22-2011, 09:00 PM
vinces2500 vinces2500 is offline
Vehicle: 1997 ram 2500
Color: red
vinces2500 is on a distinguished road
8 year 80,000 US wide
Old 01-23-2011, 09:56 AM
I had another idea. Since I was in 4wd does anyone think a hub may have unsealed since they are on vacuum and threw the code? One of the possibilties was large vacuum leak.
Old 01-23-2011, 10:09 AM
Rep:1885
Vacuum is no longer used on front axle disconnects. Even if it were the problem, the downstream sensor wouldn't throw an efficiency code. Vacuum leaks are pretty much a non-factor in fuel curve calculations with a speed density fuel system.
Old 01-23-2011, 04:32 PM
repairman003 repairman003 is offline
Vehicle: 2003 Ram 1500 4x4 4.7 Quad
Color: Green Almond Bottom
repairman003 is on a distinguished road
Where it is the rear sensor sometimes slush from the road gets splashed on them and they cool off to quick setting a code. Clear the code and see if it sets again.Then you may have a sensor or cat. problem.
Old 01-23-2011, 04:34 PM
Rep:1885
You'll have to explain how that works to me. I don't see how it could set a cat efficiency code.
Old 01-24-2011, 05:05 PM
So I took it in to have it checked out since I paid for an extended warrenty. It was the p0430 code and they ran some tests and it was slightly out of line. They called the Dealer and they said they put out an update for the PCM to extend the range for the rear sensor to prevent it from throwing the code again. It is fixed for now but the tech told me to watch for it again because if it goes off again he said I have 80k on Cat for warrenty and want to make sure it gets replaced before that expires.
