I know Im beating a dead horse - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > Exhaust
Old 01-22-2011, 09:58 PM
ramheaddodge98 ramheaddodge98 is offline
Vehicle: 2007 Dodge Ram
ramheaddodge98 is on a distinguished road
Default I know Im beating a dead horse
So im in the market and trying to figure out what im going to do for my exhaust. My biggest question is going single muffler vs true duels. Somebody told me the other day that you cant do tru duals...I thought it looked like you can cut right after the cats and run new pipe from there. Is that the case??
If so, is it beneficial to run tru duals or just go with 1 muffler? Is it worth using 2 mufflers? I had tru duals on my 6.0 silverado and loved it. Im a flowmaster guy and love having my loud and obnixous trucks. If i do that do i just run two pipes back, one for each muffler, or do you use a x pipe to help save backpressure? Im going to remove the resonators for sure.
Sorry for all the questions, i have so many people around me telling me this and that, and nobodys answers are the same. LOL
Old 01-22-2011, 10:03 PM
I've always had the understanding that you can't modify the exhaust before the cats . I've seen Chevys with dual cats , dual pipes , going into one dual inlet/dual outlet muffler from the factory . I don't see why you can't do it .
Old 01-22-2011, 10:06 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
On my 5.9 I've just ran one cat into 2 Flowmaster 40's, and straight out the back. I don't see why you couldn't run off a split before the cat, and then throw another cat in for more flow.
Old 01-22-2011, 10:47 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2018 Ram 3500 Laramie
Color: Pearl White
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:178
Burkdadhemi has a spectacular aura aboutBurkdadhemi has a spectacular aura about
Yes you could do what you just said and cut the pipe after the cats, You can modify your exhaust after the cats anyway you want too. Will it help the HP/TQ It's debatable your adding more restriction with another muffler and adding friction with another pipe. IMO unless the cats are gone it's just not worth the expense on a stock engine.
3500 Megacab 4x4 4:10 Gears
Laramie 6.7L Asin Trans
385Hp 930Tq
Pearl White
Old 01-23-2011, 01:13 AM
As long as you have a cat on both sided, sensors in place and a crossover pipe downstream, there's no real reason not to run true duals unless you can't physically fit two pipes and mufflers under there.
Old 01-28-2011, 12:35 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
you can fit 2 pipes pretty easily all the way back..
my muffler is huge...you can put 2 smaller ones in it's place...
Old 01-28-2011, 09:32 PM
ScatPak07's Avatar
Rep:970
Yea true duals are a possibility if you bring it to a good shop. You should look into going from the headers back. True duals basically means both sides breath on their own. The thing is you would have the X pipe in between them to create some backpressure. You will need to get 2 cats and 2 mufflers. You will need to mock it up first to make sure it will work.
If you get a true true dual set up done then the performance and sound will be great!
Old 01-29-2011, 08:28 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Looks interesting under there, are this cut-outs?
Old 01-30-2011, 01:35 PM
chefred112's Avatar
Rep:656
yes, the 2 valves you see are cutouts...that way when I really want my true dual sound before the muffler...I just open them up..
