Old 01-22-2011, 08:59 PM
kingator's Avatar
kingator kingator is offline
Vehicle: 2005 dodge ram 1500
Rep:87
kingator will become famous soon enough
Cool speker question and thanks for the HELP!
I want to put in 3.5" dash speakers in my '05 ram 1500 quad cab. Can anyone tell me, if there was no speaker there ever would it be wired steel?
the speakers im talking about is the roughly 6" wide piece that runs along the windshield.
And could i just use tho's wirers or would i have to run new?
has anyone done this?
and well any 3.5 fit in there?
thanks guys!!!
Old 01-23-2011, 09:33 AM
Jersey Devil's Avatar
Jersey Devil Jersey Devil is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Metalic Silver
Rep:50
Jersey Devil will become famous soon enough
Hello, that year had a 7 speaker and 4 speaker set up from the factory. From what your asking I'm going to assume you have the 4 speaker truck. You will need to run speaker wires for the new speakers your going to install. You are correct the 3.5" speakers are the size required for that truck. Good luck with your install.
Just a little FYI, to remove those covers on the dash just remove the pillar cover and it will lift out of the way, very easy to access.
When running the new speaker wires be careful not to force anything you don't want to knock anything out of place under the dash. Its easy to run the wires just take your time.
Old 01-23-2011, 03:24 PM
kingator's Avatar
Rep:87
so theres three speakers up there? are they all 3.5"?
Old 01-23-2011, 03:25 PM
kingator's Avatar
Rep:87
and ya i do have the lower mod with only 4
Old 01-24-2011, 04:46 PM
blownengine's Avatar
blownengine blownengine is offline
Vehicle: 2003 Dodge Ram
Trim Level: SLT Sport Package
Rep:35
blownengine is on a distinguished road
Do you have an amp to power those 3.5's?
Old 01-24-2011, 06:10 PM
kingator's Avatar
Rep:87
no i dont
kingator's Avatar
Rep:87
and yep theres room for 3 im thinking ill just put two in tho the two sides
Old 01-24-2011, 06:12 PM
Forget doing the center channel speaker. 3.5's will fit up there. You may even have the mounting tabs. The only way to see if you have the wiring there is to pop off that defroster vent panel and see.
Old 01-24-2011, 06:21 PM
kingator's Avatar
Rep:87
ya i do have the mounting tabs so im just going to go with the two i bought and then ill work my way to the back for the subs
Old 01-24-2011, 06:26 PM
kingator's Avatar
Rep:87
and so far that i can fill is theres no wire there for me but ill find out once i get them and start at it and take a closer look
