Old 01-23-2011, 01:30 PM
mike81's Avatar
mike81 mike81 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: big horn
Color: silver
mike81 is on a distinguished road
Default tow hooks 2010 1500?
i did not get dealer tow hooks, thought they looked weak.i'm finding out there aren't many options. any advice front or rear, hoping to solve this problem.
thanks a lot,
mike
MIKE81
Old 01-23-2011, 02:19 PM
Theres a bunch of stuff on Ebay . I'd have to say the factory hooks may look cheap , but I've never seen one break . I personally would stick with the factory ones . Not alot of modification to do to make them work .
Old 01-23-2011, 02:32 PM
mike81's Avatar
Color: silver
they barely even show, that's the most annoying part of all.if you needed to use them you couldn't fit much between the bumper and hook.
MIKE81
Old 01-23-2011, 06:21 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
OEM front hooks are pretty stout. Go by a lot on a Sunday or at night and check out a Ram with them. If you don't have the hooks, you probably don't have the skid plates either. Just an FYI.
For the rear, I've never seen any.
Brian:
Old 01-23-2011, 06:41 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
I agree with the above. The OEM hooks are strong - I believe they are rated at 5.5k lb a piece. I think that is pretty good and doubt you would ever need or want to be using something heavier duty.
If they do not protrude out far enough for you, add some steel spacers and use longer mounting bolts. I would prime and paint any spacers you use to keep rust away and have them match.
I personally would go with the MOPAR hooks but there are others out there. Hope you find what you are looking for.
Old 01-23-2011, 06:44 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
The MOPAR hooks are fine, very strong and sturdy. I installed them myself and can testify to how heavy and rugged they are. Check out my installation thread.
http://www.ramforumz.com/showthread.php?t=50811
