Old 01-23-2011, 04:10 PM
jackdanels jackdanels is offline
Vehicle: 2010 dodge ram 1500
Trim Level: trx
Rep:18
jackdanels is on a distinguished road
Default kenwood double din install
hey there i am new to this forum, and thot i would share a recent experience with you.
i just installed a kenwood dnx9960 double din head unit, in my 2010 dodge ram.
the reason i want to share this is because prior to the install i was on this forum and others researching the install. i found that many 09+ ram owners are cutting their dash and head unit rear support frame to fit the bigger aftermarket double din head units. weakening the dash ( front mount for the deck ) and, leaving the the rear of the unit unsupported, hanging off the front of the unit. to me this is alot of weight to hang off the face of the head unit. YOU DO NOT HAVE TO CUT OR REMOVE ANY PART OF YOUR DASH OR ITS SUPPORT COMPONENTS TO FIT THE LARGER AFTERMARKET DOUBLE DIN HEAD UNITS!!!!!!!!!
i will attach two fotos to show what i have dont, neither picture is great, but they show. first off i used a heat gun to make the plastic part of the stereo mount plyable, and then used a small pry bar to push the plastic up, and down to gain the extra half inch of height that is needed to accomodate the aftermarket head unit. becarefull to not heat it up too much, or distort the upper sectcion where the two upper dash screws go. second i basically beat the inner frame open just enuf to fit the head unit, but still be snug on it. and thats bout it. be patient take your time.
Old 01-23-2011, 07:14 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
great idea thanks!!!!!!
welcome to the forum!!!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 01-23-2011, 08:17 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Good job and great choice on head unit. I wa debating between that one and the one I have..
Old 01-24-2011, 10:17 PM
TALLA's Avatar
TALLA TALLA is offline
Vehicle: 2008 1500 Dodge Ram Quad Cab
Trim Level: RAM 1500 Big Horn
Rep:56
TALLA will become famous soon enough
Send a message via MSN to TALLA
nice mod to make the radio fit
2006 Chrysler 300C 5.7 Hemi
2008 Dodge Ram 1500 Quad Cab Big Horn 5.7 Hemi
Old 02-02-2011, 09:51 PM
tat2freddy tat2freddy is offline
Vehicle: 2010 Ram
Color: Brilliant Metallic Black
tat2freddy is on a distinguished road
Default What did you use?
I'm getting audio equipment together to do a complete install. Any ideas on wire harness adapters for an after market stereo?
Old 02-19-2011, 08:10 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
What equipment are you going with? I'm wanting the non-Nav version of this head unit, the DDX-896.
Old 02-19-2011, 11:52 PM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2012 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Looks good. I am about to install my Pioneer AVH-4200 next week on my 2011, so I will copy you idea, I also don't want to cut my anything on my dash. Thanks for the pics.
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 02-19-2011, 11:59 PM
SslagleZ28's Avatar
SslagleZ28 SslagleZ28 is offline
Vehicle: 2002 Dodge Ram
Rep:158
SslagleZ28 has a spectacular aura aboutSslagleZ28 has a spectacular aura about
Great info, thanks for sharing
Backlash
Semper FI
