Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 01-23-2011, 06:03 PM
jonnydd jonnydd is offline
Vehicle: 2007 Dodge Ram 1500
jonnydd is on a distinguished road
Default My Trailer brakes have stopped working
My Trailer brakes have stopped working. I have a Husky Quest brake controller which has worked perfectly for the first 8 months I owned it. On our last trip, when we went to leave, the display on the brake controller was not lighting up and the trailer brakes were not activating. When I press the manual override button on the brake controller, it does then light up on the display, but does not seem to activate the brakes. I checked the voltage at the tow plug (with no load) and with or without the brakes actuated, the voltage is about 4.4 volts DC. Does any one know what this voltage should be both with brakes on and off? Any suggestions anyone has on troubleshooting this is appreciated. I am just trying to avoid paying the dealer and having it in the shop.
Thanks,
Jonnydd
Old 01-23-2011, 06:09 PM
Rep:1885
At maximum power on the brake controller, you should have something close to battery voltage. The symptoms you describe make me think it's related to the wiring going to the stop lamp switch or the switch itself. Are you using the blue factory plug in to connect to the controller?
