Old 01-24-2011, 12:34 AM
bucholj's Avatar
bucholj bucholj is offline
Trim Level: Bighorn
Rep:26
bucholj is on a distinguished road
Question Question for Northerners
This has been a miserable year for us in North Dakota and it seems like the roads are never completely clear of snow where I am at. This question is for the others who deal with a good amount of snow each winter. Do you guys find yourself staying in 4WD Auto most of the time during the winter? I am still a little sketchy on the whole “auto” mode, it seems to work good almost too good. I guess my bottom line question is will I damage my truck leaving it in 4wd Auto as much as I do?
Old 01-24-2011, 02:45 AM
2011Ram's Avatar
2011Ram 2011Ram is offline
Vehicle: 2011 Ram Sport QC 4x4
Trim Level: Sport Premium
Rep:85
2011Ram will become famous soon enough
Shouldn't hurt it. Sometimes I have been on winter roads crossing muskeg and my truck will stay in 4WD high for months on end even at highway speeds. Sucks fuel of course though. When I was doing seismic it never came out of 4WD until spring unless I actually got to go home on some nice dry pavement.
Old 01-24-2011, 06:27 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I'm sure that someone will correct me if I'm wrong here, but this is my understanding of how "auto" 4WD works.
It's not a true 4WD system. It's more of a limited slip type of thing between the front and rear wheels, where when the rear wheels start to slip, then the front will kick in to help pick up the slack so to speak. Where with a true 4WD system, the front and rear wheels are locked in constantly.
That being said, you could conceivably run your truck in "auto" mode always and not worry about damage anything by running it where the need for "normal" 4WD might do some damage.
Exco
Bill
Old 01-24-2011, 11:25 AM
2011Ram's Avatar
Rep:85
For variable driving conditions, the 4WD AUTO mode
can be used. In this mode, the front axle is engaged, but
the vehicle’s power is sent to the rear wheels. Four-wheel
drive will be automatically engaged when the vehicle
senses a loss of traction. Because the front axle is engaged,
this mode will result in lower fuel economy than
the 2WD mode.
Old 01-24-2011, 11:41 AM
HerRam's Avatar
HerRam HerRam is offline
Rep:567
HerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to all
hmmmm that's a great question...I don't think I have the 4wd 'auto - mode' but my Ford had it and it was great and NEVER did any damage.
I wish my truck now had it because I find myself locking it into 4wd to get going from a stop sign.
it is desgined for exactly this reason...to kick it in when you need it and that it will turn off when you don't so you don't always have to be locking into 4wd. I guess it would help with fuel consumption as well. It really is a great option to have.
http://i307.photobucket.com/albums/nn293/angelgirl3_23/Snowpics008-2.jpg
Mods to my Pavement Pounding Princess :
K&N drop in filter, 'stubby' antenna and
PINK FUZZY DICE!!!
Old 01-24-2011, 11:45 AM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
We have snow on the ground for usually 5 months of the year where I live. That being said, I switch in and out of Auto depending on the road conditions. They plow the streets usually within a few days of big snow falls and if there is a more than a few inches of snow on the ground I throw it in Auto to gain the extra traction. Once they plow the roads clear and its just hard pack snow or ice, I switch back to 2WD to save fuel.
Old 01-24-2011, 12:15 PM
You will not damage your transmission other components by being in Auto for extended periods.
Old 01-24-2011, 01:46 PM
x96mnn x96mnn is offline
Vehicle: 2014 3500 DRW Crew Cab RAM
Trim Level: Farmers Package
Rep:28
x96mnn is on a distinguished road
Excoastie is bang on.
The system you have is limited so it only kicks in when needed. You will even find less of a fuel difference then I would as I only have 4hi and 4 low. You would be able to put it on four auto 365 days a year, some of the rigs out there actually have it as its only option. Most Utility cross overs who state all wheel drive use a similar set up, the one you have just happens to be the same used in the JEEP
Old 01-24-2011, 10:48 PM
bucholj's Avatar
Trim Level: Bighorn
Rep:26
I truly appreciate all the replies and they have helped put my mind at ease. I ended up putting almost 300 miles on my truck today running back and forth between two cities. On the highway I just ran in 2WD as they were fairly clear and when I hit the city limit I switched to 4WD auto to make things easier dealing with the messy intersections etc.
I am really digging this 4WD Auto.
Thanks Again!
P.S. as an added bonus today the UPS man delivered my Go Rhino Nerf Steps, Will be installing those tomorrow.
Old 01-24-2011, 10:54 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
4WD Auto is great, so glad that I have it on mine. Re, Rhino Nerf Steps. Congrats on the purchase and don't forget to post up some pics during and after the install.
