Old 01-24-2011, 03:31 AM
elcliffo elcliffo is offline
Vehicle: 2003 Dodge Ram 1500
Color: Blue
elcliffo is on a distinguished road
Default New Gears, what type of gear oil should I run??
Hey Guys,
Have a 2003 ram 1500 4.7L. It had 3.55 gears and I just replaced them with Motive 4.10s (I am in the process of breaking them in right now). Open differential, no LSD.
Dodge of course recommends 75w-140 synthetic oil in the differential, but the information that came with the motive gears called for 80w-90. I called a local 4x4 shop and they said if they were the ones changing the gears, they would have put in conventional 80w-90. So after installing the new gears I put in 80w-90 Lucas Heavy Duty Gear Oil and all seems to be working good right now.
Was this good oil to put in? After the break in should I go back to the synthetic stuff? If i do, how carefull do I need to be about mixing some of the residue of the dino oil left in the differential with the synthetic stuff? I did the gear change to improve my towing and plan on towing a lot?
thanks
elcliffo
Old 01-24-2011, 08:47 AM
Rep:1890
The oil you have now is good stuff but if you changed gears because you're going to tow a lot, I'd recommend breaking in your new gears with what you have and then switch back to the 75W-140 synthetic.
3.55, 4.10, differential, lucas gear oil, new gear change
