Latest Vendor News |
| Dodge Ram Accessories! |
01-24-2011, 08:40 AM
Vehicle: 1996 dodge ram
Trim Level: larimia
Color: red
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Rep Power: 0 Rep:10
Battery Box Removal
Has anyone tried removing battery boxes in dodge trucks? I have a 1996 Ram dually and I'm trying to get to the cruise diaphram under the driver side battery box. I've removed all nuts and bolts I can see but it won't budge! It looks like it is also fastened to the wheel well, but the bolt head is round and flat!?
Trying to fix the cruise control. The light comes on but it won't set. Mechanic buddy told me to check the vacuum hose on the diaphram.
Enjoying the forum!
Thanx
RamForumz.com | Dodge Ram Forum | Dodge Ram Forums | Dodge Ram Performance | Dodge Ram Accessories | Custom Dodge Ram | Dodge Truck Forum | Ram Truck Forum
01-24-2011, 08:53 AM
Technician On A Mission
From under vehicle, and in front of left front wheelhouse, remove 2 lower battery tray nuts.
01-24-2011, 09:07 AM
Trim Level: larimia
Color: red
Rep Power: 0 Rep:10
Qick response!!! Thank you.
01-24-2011, 09:09 AM
Trim Level: larimia
Color: red
Rep Power: 0 Rep:10
Does anyone know where I can get a downloadable PDF service manual?
01-24-2011, 09:25 AM
I don't know offhand. I get mine straight from Chryslers service info.
01-24-2011, 11:19 AM
Trim Level: larimia
Color: red
Rep Power: 0 Rep:10
There is a wheel well cover over those nuts. Is that hard to remove ramtech?
01-24-2011, 11:28 AM
No, not really. It just takes a bit of maneuvering to get it out.
01-24-2011, 11:45 AM
Trim Level: larimia
Color: red
Rep Power: 0 Rep:10
How does the clips work that hold it in? Do you push that button in the middle to release?
01-24-2011, 11:52 AM
01-24-2011, 01:34 PM
You may have to drill out some of those plastic push-in rivets so having a few on hand would be a good thing. Most auto parts stores carry Dorman fasteners. Not sure but I suspect those are at least a 1/4" diameter rivet.
