Old 01-24-2011, 11:44 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Default Running 87 octane with forced induction?
My co-worker said you can run 87 octance with a forced induction application, because it will cause detonation. Any info on this will be much appretiated.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 01-24-2011, 11:52 AM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
even n/a the hemi's need 89, any type of forced ind or n20 need the highest you can get
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 01-24-2011, 11:57 AM
Rep:1885
Not necessairly the highest you can get but it does need to prevent detonation with a given setup.
Old 01-24-2011, 11:59 AM
Well, you DON'T want detonation so I'd be looking for a higher octane than 87 even normally aspirated.
Old 01-25-2011, 07:45 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Your tuner could write you a tune for 87 but with the timing dialed back that far you'd be leaving A LOT of power on the table compared to running 93. So technically you could but you wouldn't want to.
Old 01-25-2011, 07:54 PM
ScatPak07's Avatar
Rep:970
I guess you can do it but I dont see it being beneficial. If your putting a turbo on the truck you should not be looking to save $3 every time you hit the pump. You wont get the power out of the turbo, so put 87 in and scrap the turbo idea haha
Old 01-26-2011, 07:29 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
i stick with 91 or 93
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 01-26-2011, 08:24 PM
I push the skinny pedal
Rep:3277
The higher the octane, the more resistant the fuel is to detonation, which is a major problem especially with running a turbo. You want to reduce the chances or detonation, and running 87 is just counter-intuitive to the whole process.
Kurtis
