United Radio
Old 01-24-2011, 02:55 PM
Ixzhaust Ixzhaust is offline
Vehicle: 1996 Dodge Ram
Ixzhaust is on a distinguished road
Smile Truck Revs By Itself Help!!!
I have a 1996 dodge ram v8.. its an automatic.. and lately i've been having this problem where the truck revs up and down by itself when im driving, in park, and in reverse.. please help me.. i tried TBA.. throttle body adjustment.. but i don't even know if that works haha.. i think its an electrical problem.. because i just recently changed the timing belt, oil, spark plug and wires.. please help me!!
Old 01-25-2011, 12:48 AM
Way2sly's Avatar
Way2sly Way2sly is offline
Vehicle: 08 ram 1500 (bighorn)
Trim Level: sxt
Color: blk
Way2sly is on a distinguished road
mass airflow sensor
Old 01-25-2011, 09:25 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: SLT Laramie quad cab
Color: red
Rep:52
98redbull2 will become famous soon enough
you might have a vacuum leak somewhere on the throttle body or your idle air control valve (IAC) located on the throttle body might be bad.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 01-25-2011, 10:07 AM
Rep:1824
For starters, the 5.2 doesn't have a timing belt, it has a chain, and if someone charged you to replace it, you got the shaft. Second, Dodge trucks (gas engines) don't have MAF sensors, they use speed density (MAP) to calculate the fuel curve. RedBulls suggestion is the one you need to pay heed to. Check the TB and hoses for vacuum leaks. You can do this by spraying these areas with carb or brake cleaner with the engine running and listening for a change in engine RPM.
Old 01-25-2011, 11:55 AM
HerRam's Avatar
HerRam HerRam is offline
Rep:567
HerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to all
Ramtech - like a Seafoam treatment? should clean it all out...the truck with smoke like unbelieveable but that stuff works great!
http://i307.photobucket.com/albums/nn293/angelgirl3_23/Snowpics008-2.jpg
Mods to my Pavement Pounding Princess :
K&N drop in filter, 'stubby' antenna and
PINK FUZZY DICE!!!
Old 01-25-2011, 12:02 PM
Rep:1824
You really need something in a spray can so you can direct the cleaner toward a particular area. Sea Foam does a great job of cleaning intakes though.
Old 02-09-2011, 05:50 PM
Dodger98's Avatar
Dodger98 Dodger98 is offline
Vehicle: 1998 Dodge Ram 1500 4x4 (5.2L)
Rep:12
Dodger98 is on a distinguished road
i had a similiar issue with my 98, the truck would just rev up and down (maybe 300 rpms at most) couldnt figure it out, checked for vac leaks, found nothing
replaced a throttle position sensor.?? i think, (this was a couple years ago) and problem solved, my truck would even die when the rpm's dipped that low
Old 02-17-2011, 02:54 PM
mikezram mikezram is offline
Vehicle: 1996 Dodge Ram 1500
Trim Level: off road
Color: green/silver
mikezram is on a distinguished road
i am haveing this same issue with my 5.2 only revs about 300rpms but only between 50-60 at a certain position of throttle
Old 02-17-2011, 07:25 PM
aftershokk86's Avatar
aftershokk86 aftershokk86 is offline
Vehicle: 01 ram 1500 ext cab
aftershokk86 is on a distinguished road
replaced my tps, and that fixed it.
another thing to look at is make sure your tranny is full on fluid, in neutral.
01Ram: infinity reference 6x9's/5.25's|kicker 12cvt|400w4channelamp|2500wmonoamp|
Old 02-19-2011, 09:49 AM
Color: green/silver
well $38 at the local part store...eh ill try it thx, ill post up the let you know if this helped me
dodge ram revs by itself
