Old 01-24-2011, 06:03 PM
USCG4.7's Avatar
USCG4.7 USCG4.7 is offline
Vehicle: 2012 dodge RAM
Color: Pewter (dark silver)
USCG4.7 is on a distinguished road
Default Let's have a talk about gears!
Ok so when I irate got my truck it had the factory 17" wheels and factory rubber, I upgraded to factory 20" wheels and 275/65/20's witch equal a 22.9 inch tire/wheel combo. I was sa becues I lost a lot of low end get up and go. And let's face it a 07 ram 4.7 needs all the low end help it can get. So I'll give dodge a call and find out that I have 3.55 gears in the back.... This is not going to do for me!!!!
So it's like this, from here we can go 3.73, 3.92, 4.10, or.... 4.56
It's a two wheel drive quad cab. I'm leaning with the 4.10's but keep hearing about 4.56... However I have herd about harmonics, and having to make the case a lil bit bigger. So what's everyones thoughts, and yes I know gas "may" suffer but let's face it... It's an extremely heavy truck with dang big rims and tires and some little gears. From math it would seem that it may run a lil better. Does any one have any real life knowledge about there trials and tribulations?? In any event I'm going to spend a week getting REAL life readings... This will include RPM's at 55,60, and 75 mph.. Let's face it we don't all drive like that. I will also do a mpg tracking using each of the three octane levels for a week. I will do this with the 3.55's and then again with whatever gears I get.
Old 01-25-2011, 08:46 AM
RamTech RamTech is online now
Rep:1885
Given your combination and what it sounds like you want, 3.92 or 4.10 will be your best choices. 4.56 gears are better suited to 35" tires or bigger or the drag strip. 3.73 won't give you the change you're looking for; you'll hardly notice a difference.
Old 01-25-2011, 03:10 PM
USCG4.7's Avatar
Thanks man I have been doing alot of thinking and I am going to go with 4.10's. And I fully plan on putting it thru the challenge that I stars I'm at an 8th tank right now so a lil bit longer and I'll start number crunching.
Old 01-25-2011, 03:31 PM
Bodydoc2002's Avatar
Bodydoc2002 Bodydoc2002 is offline
Vehicle: 2009 Dodge Ram 1500
Rep:138
Bodydoc2002 will become famous soon enoughBodydoc2002 will become famous soon enough
Even with 35 inch tires and lifted I like my 4.10s...Still has lots of get up and go...No problems towing...Good gear...
2009 2WD Ram 1500. 7 inch CST Lift. 35 inch Mickey Thompson BAJA ATV. 20 inch ATX Artillery wheels. TOFF Spray in Bed liner. N-Fab 6 step Nerf Bars. BushWacker Pocket/Painted Fender Flairs. Diablosport Predator. K&N CAI 77 Series. 180 Thermostat. LED Tailgate lights.
