Question about my brakes - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8
Old 01-24-2011, 10:53 PM
Widowmaker Widowmaker is offline
Vehicle: 1996 dodge ram sport
Widowmaker is on a distinguished road
Default Question about my brakes
today as i was comming to a red light i hit the brakes and it felt like i was pressing on a brick. when im at a high speed and pump the brakes the first pump is soft and works fine as well as the second but when i pump it for a 3rd or 4th time it feel like that brick feeling. the truck slows down but barely if i dont touch them for awhile it does the same thing any idea's?
Old 01-25-2011, 12:02 AM
When was the last time you had the braking system bled and new fluid put in? Also, I'd suggest you look into some braided steel lines to replace the old rubber ones which are probably worn out and expanding too much.
Old 01-25-2011, 12:15 AM
Rep:2954
10 year old brake fluid?
drum or disk or both
old rubber lines
hone brake cylinders
wheel cylinder kits
EBC pads
don't worry, i'm just thinking in text
Old 01-25-2011, 10:20 AM
lol well i just bought new lines 2 months ago with the brake fuild. so im confused
Old 01-25-2011, 10:23 AM
Resident Technician
Rep:1915
A high, hard pedal with the engine running indicates either a loss of vacuum to the brake booster or a failing booster. The other problems listed above tend to give a low, spongy feeling pedal.
Old 01-25-2011, 10:47 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
yup ramtech is right i had a chevy pickup where the brakes were good (sometimes) but got stiff often and eventually had no power brakes so ur brake booster is the best bet. and a change of all your old brake fluid would be good too.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 01-25-2011, 02:35 PM
thanks guys
