P0132 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-24-2011, 11:52 PM
uptheirons uptheirons is offline
Vehicle: 2003 Dodge Ram
Color: Tan
uptheirons is on a distinguished road
Default P0132
had this code for a little while, tried replacing both 02 sensors, came back both times... i'm sure this has been posted in the forum before but i couldn't find it. My Haynes manual says "Upstream oxygen sensor (left cylinder bank), circuit voltage too high.
Any insight from anyone? anyone had this problem before?
Thanks in advance!
Old 01-25-2011, 01:04 AM
Pecos Bill Pecos Bill is offline
Pecos Bill is on a distinguished road
What does that mean?
This involves the front oxygen sensor on Bank 1. This code indicates that the heated oxygen sensor reading is too high. That indicates the voltage at the sensor is over 1.5 volts. You will likely not notice any drivability problems.
Causes
A code P0132 may mean that one or more of the following has happened:
  • <LI itxtvisited="1">The oxygen sensor heater circuit is shorted out
  • The wiring to the sensor is broken / frayed (less likely)
Possible Solutions
The simplest thing to do is to reset the code and see if it comes back.
If the code comes back, the problem is more than likely the front Bank 1 oxygen sensor. You will likely wind up replacing it but you should also consider these possible solutions:
  • <LI itxtvisited="1">Check for wiring problems (shorted, frayed wires)
  • Check the voltage of the oxygen sensor
http://www.obd-codes.com/p0132
Old 01-25-2011, 01:09 AM
Color: Tan
I'll give it a try! thanks.
Old 01-02-2017, 02:43 PM
Nupe Nupe is offline
Vehicle: 2002 dodge ram
Color: burgundy
Nupe is on a distinguished road
Old question but the same. Where is this sensor? i only see the upstream but on the passenger side. Nothing is in the exhaust on the drivers side.
