Old 01-25-2011, 10:53 AM
Tayloor Tayloor is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: Quad Cab
Color: Blue
Tayloor is on a distinguished road
Question What is the biggest tire i can ride on a factory ride hight 15
I have a 2002 dodge ram 1500 with the factory 17s i was wondering what is the tallest offroad tire that i could install on the factory ride hight? thanks for the input guys and gals
Old 01-25-2011, 11:52 AM
Rep:1885
If memory serves, you can safely run a 285/75R-17. Keep in mind not all tires are created equally and some will be taller or wider than others even thought they're sized the same.
Old 01-25-2011, 01:06 PM
That ^^^^ would be the max and, as he said, tires do vary from mfgr to mfgr. You may end up having to run a 65 series vs. a 75 series depending on whose tire and what style, i.e., highway tread vs. off-road tread.
Old 01-25-2011, 01:08 PM
Rep:1885
Or a 70 series...
Old 01-25-2011, 01:11 PM
yeah...true...70's would probably work.
Color: Blue
thanks again for the info it will be helpful on my search for tires
Old 01-25-2011, 01:35 PM
And there's no reason why the tire store can't test mount a 65, 70 or 75 series tire for you to check clearance.
Old 01-25-2011, 01:43 PM
Rep:1885
They certainly will if they want to make the sale.
Old 01-25-2011, 07:20 PM
ScatPak07's Avatar
Rep:970
I would have to agree with the guys above. A 70 series might be the better way to go with a stock truck.
Old 01-27-2011, 07:46 PM
chrisp chrisp is offline
Vehicle: 05 ram
Color: silver
Rep:12
chrisp is on a distinguished road
i just put 285/70/17 on stock rims, with no lift or level,
they are goodyear wrangler territorys similar to the duratracs
ill post a pic if i can figure it out lol
