Old 01-25-2011, 10:59 AM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
Default Service 4WD light
This morning it was really cold and snowy, -3 F, I let the truck warm up for just a little bit (5 mins) because it was already plugged in.
Started driving down the road going about 40 mph, and the Service 4WD drive light came on. I continued to drive and the 4WD seemed to work fine. I stopped a little up the road, shut the truck off, and started it back up. Continued on my drive to work in 4WD the whole time (about 40 mile drive on the highway) and the light never came back on.
So, was it a computer glitch because the transfer case was really cold, or something else wrong? Does that light only mean there is something wrong, or does it indicate change oil as well. Curious why it never reappeared?
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 01-25-2011, 11:03 AM
Rep:1890
Difficult to say what it could be but a code should be stored in the DTCM. The light doesn't come on at service intervals. Let the dealer have a look at it.
Old 01-25-2011, 01:31 PM
KGVette's Avatar
KGVette KGVette is offline
Vehicle: 2010 Ram 1500
KGVette is on a distinguished road
I have a buddy who purchased a 2011 slt about a 2 months ago. In that time and about 2000 miles he had his truck in 5 different time with issues relating to the service 4WD light coming on. After the fifth time he took it back and said enough and gave them the keys. They ended up taking his truck back and giving him another one. Never could come up with what was going wrong
Old 01-25-2011, 02:13 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Do a search on service 4wd and you'll find that quite a few people have had this issue. I am currently waiting for a tranfer case shift motor that is on back order for mine. I hope this fixes it but a lot of people have had their final drive control module or wheel sensors replaced to fix it. I'd take it to the dealer now it may take them a while to track it down it seems
Old 01-25-2011, 02:18 PM
Rep:1890
That's a very uncommon problem you have with yours.
Old 01-25-2011, 05:03 PM
AKFossil's Avatar
AKFossil AKFossil is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Inferno Red
Rep:57
AKFossil will become famous soon enough
the service light could be as simple as a wheel sensor that didn't respond for a short period to needing a transfer case. I would mention it to the service adviser on your next visit unless it happens again then I would just call them and ask if you should bring it in for a quick look.
2010 Dodge Crew Cab Inferno Red: HID Low Beams & Fog Lights 6000K, LED Interior Lights, LED License Plate Lights, Black Nerf Bars, AVS Bug & Window Deflectors, K&N Drop In Filter, WeatherTech Floor Mats, Goodyear Wrangler Silent Armors, MagnaFlow Muffler
Thinking about: New Wheels, and leveling kit.
Old 01-29-2011, 10:04 PM
therock2086's Avatar
therock2086 therock2086 is offline
Trim Level: Big Horn SLT
Color: Deep Water Blue Pearl Coat
therock2086 is on a distinguished road
i've never had that happen and I wouldnt worry about it unless it comes back on
Old 02-05-2011, 06:02 PM
jwsnowman jwsnowman is offline
Vehicle: 2011 Dodge Ram 1500
Rep:27
jwsnowman is on a distinguished road
I had the very same problem the other day but my truck wouldn't go into 4wd even when the selector was in 4wd and the 4wd light was on. After stopping, putting the selector into two wheel drive, doing a few donuts, turning it off, and then back on...the serv 4wd light didn't come back on and my 4wd worked with no problems. I had a hunch that it was most likely a frozen wheel speed sensor...if the truck can't tell how fast it's going, it won't shift into 4wd. The serv 4wd light does still come on at start up but then disappears...I'm guessing its because the error code is probably still stored in the truck's memory. The truck is going in on Monday for the dealership to take a look at another issue so I'm going to mention it to them and see if they can see the error and can clear it and hopefully that will stop the serv 4wd light from coming on at start up. Like I said, it does go out a couple seconds later but its still a nuisance.
