ZDOG
Old 01-25-2011, 01:45 PM
geek82's Avatar
geek82 geek82 is offline
Vehicle: 2010 Ram 1500
Trim Level: TRX-4
Color: Mango Tango
geek82 is on a distinguished road
Default TPMS Sensors & Cold Weather
A couple days ago we had some cold weather roll through (-22C). The TPMS complained about low pressure in driver side rear tire. The pressure came back up once we hit the road, but the ( ! ) Light keeps coming on. This happen to anyone else? Thought it was interesting.
Old 01-25-2011, 01:57 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
yep did it to me a month ago when the weather started getting cold. I topped the tires all up to 40 psi (rating for my 17 tires according to the door frame sticker) and that took care of it. Odd thing was all the tires were around 33-34 psi, filled the 35 and the light still wouldn't go away after driving around, so went with 40.
I thought nitro was supposed to last longer? if the were at 40 and went down to 33 - 34 that is alot gone in less than a year?
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 01-25-2011, 02:06 PM
Resident Technician
Rep:1911
Sounds like normal operation to me. Set the tire pressure when the tires are cold and the problem should go away.
Old 01-25-2011, 02:26 PM
KGVette's Avatar
KGVette KGVette is offline
KGVette is on a distinguished road
My passenger rear said it was 2 lbs. low the other day. I also put some in and they all read the same but like the op said the light is still on saying it is low. I too would like to know if there is some sort of reset for this or is it suppose to go away on its own?
Old 01-25-2011, 02:27 PM
Resident Technician
Rep:1911
The sensors shouold update while you drive. This could take up to 10 miles.
Old 01-25-2011, 02:36 PM
KGVette's Avatar
well that is what I thought, I'll keep an eye on it, thanks for the info RamTech
Old 01-25-2011, 08:42 PM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
I just went through all this over the last 2 days. Temperature outside hit -26C and all 4 tires were flashing in the EVIC. I'm not sure what the low threshold is before it sets the light on and starts flashing, but the only way for it to reset is to inflate whatever tires show low to the recommended pressure found on the sticker on the B-pillar inside the driver's door.
I inflated them to 35psi (per the sticker), but that was in a heated garage. As soon as they got cold they were below that pressure and didn't hit 35psi in the EVIC to reset the system. Check the pressure with a good gauge while the truck is outside - figure out how many pounds of air you're short and add that plus an extra .5psi to be sure.
From my research, you lose a pound of pressure for every 10 deg drop in temperature. If you are inflating the tires in a heated garage that's at 5C then taking it out at -25C then you just lost 3 pounds of pressure - so over-inflate the tires at 5C by 3psi and you're golden.
Old 01-29-2011, 09:30 PM
therock2086's Avatar
therock2086 therock2086 is offline
Trim Level: Big Horn SLT
Color: Deep Water Blue Pearl Coat
therock2086 is on a distinguished road
same thing happend to me and i put 35 psi in and that did the trick cause when i bought it there was only 32 in it and we had a day that was like 1 degree out and i pumped it up to 35 and it went off, they say in the owners manual to add air then drive above 15mph for at least 20min and it will rest itself but it didnt take that long for mine
