Old 01-25-2011, 01:26 PM
jokkling jokkling is offline
Vehicle: none (yet!)
jokkling is on a distinguished road
Default MPG / Wheel Size
Ok, so I was just thinking. Everyone is pretty convinced that putting bigger tires on your truck will lower the milage. But how many of you calculate with that your truck will travel a grater distance with bigger tires? I mean, let's say you have 28" stock tires and put on 35" tires. The perimeter is about 25% longer on the 35" tires. If you don't compensate by this when you calculate your new mpg then you will get a incorrect mpg. Let's say your mpg was 15 with the stock tires. then with the new tires you will get 12 mpg traveling the exact same distance using the exact same amount of fuel.
In theory putting on bigger tires would be the same as swapping to low gear axles - which in most circumstances uses less fuel.
Excuse my crappy English, I'm from sweden...
Old 01-25-2011, 02:54 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
I think your logic is a little flawed. Larger tires are heavier and have a larger diameter, therefore they require more power to turn them and keep them turning. Period.
Old 01-25-2011, 03:33 PM
Bodydoc2002's Avatar
Bodydoc2002 Bodydoc2002 is offline
Vehicle: 2009 Dodge Ram 1500
Rep:138
Bodydoc2002 will become famous soon enoughBodydoc2002 will become famous soon enough
^^What he said^^
2009 2WD Ram 1500. 7 inch CST Lift. 35 inch Mickey Thompson BAJA ATV. 20 inch ATX Artillery wheels. TOFF Spray in Bed liner. N-Fab 6 step Nerf Bars. BushWacker Pocket/Painted Fender Flairs. Diablosport Predator. K&N CAI 77 Series. 180 Thermostat. LED Tailgate lights.
Old 01-25-2011, 04:06 PM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
That's something I would tell my girlfriend/wife in order to justify my bigger lift and tire purchase.
Old 01-25-2011, 06:11 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
usually when you put bigger tires you are also putting wider tires which creates rolling resistance.so even if you are traveling the same distance ,more distance,or even less distance you are using more gas no matter how you calculate it!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 01-25-2011, 08:48 PM
ScatPak07's Avatar
Rep:970
Funny thing is that he is right. Sorry to burst all your bubbles.
Yea on the highway you will get better MPG since you lowered the gear ratio of the truck. When your in the city you will have less since you are carrying more weight. In my truck I actually gained some MPG when on the high way a lot. After a while the MPG stayed about the same on my computer.
This concept is messed up but it works.
For the smart asses out there, yes I did change my speedo haha. My truck with a 6" lift and 35" tires gets over 13 MPG average. That is the norm for the 3rd gen Rams, at least mine was when it was stock.
If you do lots of city, or mostly city then you will notice a hit in MPG since your trucks working harder to move those big basterds
I know everyone is going to argue with me on this one hahahahaah
Old 01-26-2011, 05:20 PM
Rayne's Avatar
Rep:73
Yeeeeah, I'm not buying it. Sorry.
Old 01-26-2011, 05:57 PM
Well, I don't doubt that bigger tires will decrease your milage in the end. But I don't think it's as bad as many thinks. I mean, come on, none of you can't deny the fact that you travel a greater distance with bigger tires, which won't show on your odometer, right?
Old 01-26-2011, 05:58 PM
foxcrazy90's Avatar
Rep:584
mine gets better to on the highway (down hill)
NEIL KELLEY
Old 01-26-2011, 06:09 PM
KennyPowers's Avatar
KennyPowers KennyPowers is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:299
KennyPowers is a jewel in the roughKennyPowers is a jewel in the roughKennyPowers is a jewel in the rough
You also have to factor in aerodynamics. Suspension lift + larger tires and wheels means you're sitting higher. Thus, creating more drag. At the end of the day I laugh when people complain about their mpg in a truck. It's a heavy vehicle with a big engine! Who cares what the mpg is!
