Old 01-25-2011, 10:55 PM
redhemi06's Avatar
redhemi06 redhemi06 is offline
Vehicle: 2006 Dodge Ram
Rep:36
redhemi06 is on a distinguished road
Default e-fan with 180 t-stat
wanting to do the e-fan conversion, what temp should the fan be set to turn on and off? any how to's?
Old 01-28-2011, 10:35 AM
Resident Technician
Rep:1909
Since you're wanting to change to the 180 stat, I'd recommend a fan turn on temp of 195-200 degress.
Old 01-29-2011, 07:25 PM
liljohn30's Avatar
liljohn30 liljohn30 is offline
Vehicle: 08 lonestar hemi ram qc
Color: white/gold
Rep:13
liljohn30 is on a distinguished road
what do u need for this conv. i have the 180 stat but i cant adjust fans setting via my predator,also anyone ever firgure out how to install a catch can
Old 01-29-2011, 10:08 PM
redhemi06's Avatar
Rep:36
search catch can on forum and youll find the how-to. i already ordered the fan and 180* tstat yesterday, im gonna use haydens fan controller. all you do is set the on and off temp
Old 01-29-2011, 10:25 PM
liljohn30's Avatar
Color: white/gold
Rep:13
tks ..and someone figured out how to do the can on the closed system -08 hemis have
Old 01-30-2011, 07:51 PM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
The best fan for our trucks is the black magic 180 fan setup.
It must run with a 180 stat to work properly though.
If its setup right it will only come on while sitting at a light.
What you want to do is leave your truck running.
Once the top rad hose opens up move the fan switch on the electirc fan so it turns on.
Then back it off just enuff so it stops running.
Your setup perfectly.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 01-30-2011, 08:20 PM
redhemi06's Avatar
Rep:36
thanks thatll be very helpful once it gets in
Old 02-07-2011, 12:12 AM
06BlueMegaCab 06BlueMegaCab is offline
Vehicle: 2006 Dodge Ram Mega Cab
Color: Dark Blue
06BlueMegaCab is on a distinguished road
Question
Hey I want to do the e-fan conversion on my hemi. Where did you order your e-fans at?
Old 02-07-2011, 12:29 AM
redhemi06's Avatar
Rep:36
I ordered mine from summit racing, never had a problem with them and if you receive their emails you'll get discounts from time to time but they're online catalog is one of the best And prices are pretty good.
Old 04-12-2011, 11:04 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
what model number of fan controller are you using? found a bazillion of those online....which one?
thanks
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
