Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 01-26-2011, 02:48 AM
StevanA StevanA is offline
Vehicle: 2011 Ram 2500
StevanA is on a distinguished road
Question Do I need head studs?
If I get a tuner to increase power do I need to get head studs?
Old 01-26-2011, 09:13 AM
79ta 79ta is offline
79ta is on a distinguished road
You shouldnt unless you start upgrading turbos with higher boost levels. Anytime you add a programmer, you take a chance. I have the smarty jr and they claim the hp increase is "safe" for our trucks.
Old 01-26-2011, 10:19 AM
Rep:1845
You're a long way from needing head studs. Who told you that fairy tale?
Old 01-26-2011, 01:51 PM
so if I get the Smarty tuner I could run software #9 on it and as long as I don't have a DPF to overheat then I'm good?
Old 01-26-2011, 01:55 PM
Rep:1845
I'm not familiar with that particular tuner, but I've never seen just a tuner crank up a CTD to the point that internal modes were needed. Are you going to do the DPF and EGR delete?
Old 01-26-2011, 03:40 PM
yeah I plan on it! On the MADS electronics website the only thing they say about their 170hp tune is that if you make passes of 105 mph or higher that exhaust heat could be high enough to damage the DPF, but if I don't have a DPF then is it ok to run that tune?
Old 01-26-2011, 03:42 PM
Rep:1845
I would think so but you should e-mail them with that particular question.
Old 01-26-2011, 06:00 PM
The weak link will be the transmission for any tune over 100hp if its an automatic. I have heard of guys running a 170hp tune without issue and guys running a 100hp tune and had trans trouble. Your driving habits will have the biggest effect on parts failing.
Old 01-28-2011, 04:40 PM
Srt cummins Srt cummins is offline
Vehicle: 2005 ram
Trim Level: Custom
Color: Soon to be orange
Rep:13
Srt cummins is on a distinguished road
Send a message via Yahoo to Srt cummins
auto or manual? i would buy a h&s tuner. on a 6.7 you have to do the dpf delete and if you do go smarty its not just putting it on 9 and you have that much power each truck is different it will take a lot of tunning with a smarty
05 sc/sb swapping a 6.7 cummins into it-project street truck
Old 01-30-2011, 11:30 PM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
As has been said, the weak part is gonna be the trans if it's an auto.. While head studs SOUND cool, they are really not needed until you get to the crazy high power setups and twin turbos.
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
