Old 01-26-2011, 11:02 AM
mrroader14 mrroader14 is offline
Vehicle: 2011 dodge ram 1500
Trim Level: outdoorsman
Color: deep water blue
mrroader14 is on a distinguished road
Default 2011 brake controller
Hi, I was told by my dealer that that I cannot add an aftermarket trailor brake controller to my truck. Plus it didn't come with the normally supplied pigtail either. Also they claimed I nor they can add a factory controller either at this time. It will interfere with other computerized brake systems on the truck. Dodge is supposed to come out with a kit in late january. Im just wondering if anybody else is having this issue. Thanks
Old 01-26-2011, 11:41 AM
Rep:1909
That's a crock of BS. You most certainly can add an aftermarket unit but you may need to run the wiring yourself.
Old 01-26-2011, 12:33 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
check out this info. I would imagine that 2011 is the same as 2010.
http://www.ramforumz.com/showthread.php?t=52410
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 01-26-2011, 12:38 PM
i appreciate the info. seems as though buying a new truck is like the healthcare bill, "just sell it and we will figure it out later" lol. i imagine i will just order the factory unit at this point along with the bezel, but would like to know for sure the dealer knows how to flash the puter to recognize it. so it shows up in the EVIC.
Old 01-26-2011, 01:50 PM
x96mnn x96mnn is offline
Vehicle: 2014 3500 DRW Crew Cab RAM
Trim Level: Farmers Package
Rep:28
x96mnn is on a distinguished road
I am being told the same thing. That the plug to go to the brake control does not exist at this time for resale and that my after market unit would work if I wanted to hardwire it in which I don't.
They stated that the new controller would be out by spring to purchase. My main question is, How do they come equipped with them if it does not exist?
Either way not worth my time right now as I only need it in April so I will wait until then before I start pressing panic buttons.
Old 01-26-2011, 03:51 PM
E220 E220 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:82
E220 will become famous soon enough
i have a trailer brake control installed in my truck
is this used only for towing ,I never tow so is this useless for me , and why does it go up to 5
Old 01-26-2011, 04:54 PM
latitud's Avatar
Rep:71
Just look under the dash on the drivers side near the kick panel. There should be a taped up harness with a large plug and a small plug. If you have both plugs then you can connect directly to the oem controller. if you only have one plug, you will have to wait for the "kit" that was supposed to be available last fall.
Old 01-26-2011, 06:03 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
our new truck didn"t come withe the pigtail either i told the salesman and the service dept that they needed to get me one. both of them said they would order it.i guess we'll see what happens i don't want to run all the wires as i did on a previous truck going to the dealer on sat i'll see what they have to say
Old 01-26-2011, 08:13 PM
the dealer gave me the impression that whatever i did at this point would have a conflict with the computer or other braking systems, such as BAS or ABS,. This truck has so much electronic stuff on it compared to my previous 2006 ram. i appreciate the feedback on this matter and will continue to post info if and when i get the situation resolved. thanks again, this place is great!!!!
Old 01-26-2011, 08:15 PM
pjs1660's Avatar
Color: green
Rep:137
i just went out to the truck and got an empty zip lock bag that i thought the missing pigtail was supposed to be in it says "keep in vehicle for customer use" and the following numbers 5912577ab and m06212840b1 i tried looking them up but not could find what the missing piece was does anyone know what was in the bag? do the pigtails really exsist? thanks
