Old 01-27-2011, 11:28 AM
rinkerman rinkerman is offline
Vehicle: 2010 Crew Cab
rinkerman is on a distinguished road
What intervals do you change the oil at with the synthetic?
Old 01-27-2011, 12:56 PM
Blackzilla's Avatar
Vehicle: 2009 Reg Cab S/B 4X4
Trim Level: Sport/SLT
Color: Black Pearl
Rep:199
I change mine every 5000/6000 miles.
Old 01-27-2011, 03:47 PM
bhc1980 bhc1980 is offline
Vehicle: 2012 Dodge Ram 1500
bhc1980 is on a distinguished road
I put mobile 1 in my truck at 500 miles with no problems. Did the same for my 06 Magnum R/T and have not had a single problem and it has about 75000 miles on it now. Don't get a cheap filter and any synthetic will do the trick. I change my oil about every 4500-5000 miles and my oil is still a nice honey brown color.
I avoid Pennzoil and Quaker State like the plague from a bad experience with their regular oil, I don't know if their synthetics are worth a damn or not.
Old 01-27-2011, 05:00 PM
25 Outlaw SST's Avatar
25 Outlaw SST 25 Outlaw SST is offline
Color: Inferno Red
25 Outlaw SST is on a distinguished road
I use Mobil 1 05-20. Use it in both my wife's Escape and in my Ram. Have never had an issue when using it and I have been using it for almost 15 years.
One thing to remember, when you pick an oil, the best thing is to stick with that same oil for the duration of the vehicle. Mixing brand can actually cause problems due to their different chemical make-up. In other words the oils will work against each other and end up not giving the protection that you need.
Pick a brand and stay with it...
Old 01-29-2011, 05:05 PM
Phreak Phreak is offline
Vehicle: 2010 Dodge Ram , 1983 Jeep CJ7
Trim Level: Crew Cab Sport
Rep:20
Phreak is on a distinguished road
Send a message via MSN to Phreak
I have been told by several performence shops to do 2 oil changes first.. to get any metal out of the base of the engine (and do them at 3000 and 6000) then go full sync
the reason to keep the reg oil for the first 2 changes is really money.. since your changing them quicker.. you may as well just use reg.. then spend the bucks on the sync ... I have changed my oil once and will go full sync next change... not sure of the brand yet...
Old 02-01-2011, 01:17 AM
hemi426 hemi426 is offline
Vehicle: 2010 dodge ram
Trim Level: Sport Crew Cab
hemi426 is on a distinguished road
I believe Edge only comes in 5w30. haven't seen anything but that.
Old 02-01-2011, 01:43 AM
HEMI5150's Avatar
HEMI5150 HEMI5150 is offline
Vehicle: 2010 Dodge Ram Quad 4X4
Trim Level: SPORT
Color: Black Pearl
Rep:35
HEMI5150 is on a distinguished road
They do make 5w20, we have it here all the time
You might be able to bullshit your way to the top, BUT, it wont keep you there
Never believe what you hear, and only half of what you see
Old 02-01-2011, 01:58 AM
HEMI5150's Avatar
Trim Level: SPORT
Color: Black Pearl
Rep:35
Originally Posted by jojo13 View Post
first shouild I wait for my second oil change before going with a good synt oil or convert it at my first oil change
and should I go Royal purple or amsoil oil and filters...?
thanks
Go with synthetic oil ASAP...!
No thanks on the RP&AMS oil. (way over priced)
Mobil 1 5w20 @ walmart $22 for 5qt = per jug
(Hemi use`s 7qts, buy 2 of the 5qt jugs and save$ 3qts towards your next oil change)
Its like $1.50 per qt cheaper by buying the 5qt jugs
Be careful of what oil filter you are useing...!!!!!!!
The oil filter should be designated for synthetic use.
The factory MOPAR filter will be fine with most synthetic oils.
