Old 01-27-2011, 06:54 PM
The Wook The Wook is offline
Vehicle: 2011 Dodge Ram 1500 Sport
Trim Level: Sport Crewcab 4x4
The Wook is on a distinguished road
Default No Reverse?
So i have an odd issue with my transmission. The problem has happened twice today. I start the truck, it shifts into reverse fine, ill drive a short distance, turn the truck off hop out for approx 1 minute, hop back in, go to put the transmission into reverse and there's nothing. The cluster shows that the transmission is in reverse but it doesn't move, and you can't even feel the transmission shift a gear. I can get it to go back into gear only if i put it into Drive and then back into reverse. If i put it back into park and then reverse again after it happens, i still wont move.
The truck is going to the dealer tomorrow, just wondering if anyone else has experienced this? I checked the tranny fluid and its good so i dunno? Possibly just loose linkage or something?
Old 01-27-2011, 07:01 PM
I haven't heard of this issue before! Let us know what the dealer tells ya!
Old 01-27-2011, 07:06 PM
Will do. Truck has only 1022km's on it as it sits in my garage..... Hopefully its nothing major and can be fixed within the day.
Old 01-27-2011, 07:10 PM
gavinthered gavinthered is offline
Vehicle: 2013 Ram 2500
Trim Level: big horn
Rep:44
gavinthered is on a distinguished road
i just had this exact problem for the first time today as well..... kinda worrying. i wont be able to take it in for awhile so keep us posted on what the dealer says please
Old 01-27-2011, 08:48 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Probably a linkage or sensor issue.
www.beatcraigslist.com - for posting dangers & secrets
Old 01-28-2011, 09:39 AM
SO the truck is at the dealer now. They said they haven't heard of the problem. The advisor mentioned that maybe it just needs a software update. I can't really forsee that as the linkage is a mechanical thing but we'll see.
They are also doing any recalls while its there. he mentions the rear diff fluid being low recall. I laughed and said giver.
I'll keep you guys posted when i hear back.
Old 01-28-2011, 10:19 AM
JHamilton's Avatar
JHamilton JHamilton is offline
Vehicle: 2011 Ram Crew Cab 4x4
Color: Deep Cherry
Rep:92
JHamilton will become famous soon enough
Do these things have a mechanical linkage?
I'm a failure by standards I reject anyway.
Old 01-28-2011, 10:35 AM
Rep:1885
Yes, they do even though the RFE indicates the transmission is fully electronic.
Old 01-28-2011, 10:36 AM
Rep:1885
I just did some checking and apparently this isn't a common issue. I couldn't locate any tech support cases or bullitiens on the issue and no service flashes are available for the PCM on the 2011 model year.
Old 01-28-2011, 12:00 PM
Rep:2657
I am already considering buying a new Ram, not for a couple years of course, but, they will have the new ZF 8 & 9 speed transmissions in the Rams by then.
They are going to have the ground breaking ceremony in February at Greenville, South Carolina, where they will be building them
Bang In Reverse Noise And Hard Shift BIUBigPimpin Dodge Ram General Discussion 7 01-16-2011 01:55 AM
reverse fuse, or whatever wire i need... oaklandopen 2010 Dodge Ram Forum 1 09-28-2010 06:34 PM
Reverse and Overdrive DYNO Dodge Ram General Discussion 3 06-17-2010 12:02 AM
Noise in reverse after leveling kit Pav Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 04-16-2010 05:03 PM
No reverse in tranny YoMoma 5.9L V8 Specific Topics 16 12-08-2009 10:55 PM
