Old 01-27-2011, 11:30 PM
2011Ram's Avatar
2011Ram 2011Ram is offline
Vehicle: 2011 Ram Sport QC 4x4
Trim Level: Sport Premium
Rep:85
2011Ram will become famous soon enough
Default Underhood LED light install
I installed these underhood lights but I don't have the switch installed yet. I might go to an electronic shop and get a ball-bearing or even a mercury switch to finish. Here is what I got:
Take off the "silencer pad" off the underside of the hood by using a removal tool for the clips. Drill (or poke) a hole for the wires to go through and feed them to the inside of the pad. Splice the wires together so that you have both pos + neg from the lights connected to a single pos + neg to go to your switch.
Only the pos should be connected to whatever switch you use, the negs should be connected directly. Locate the factory plug-in for the hood light and splice into that.
Use solder all the way and shrink-wrap tubes to cover connections.
Oops. You gonna need some new hood clips. Pretty generic, just take one in with you after you kill it.
This should easily be handled by this circuit I'm guessing, as it should be designed for even more load than this.
Old 01-28-2011, 12:39 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
thats a sweeet mod dude!!!!!!!
Old 01-28-2011, 12:40 AM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
looks awesome man! gave me a few ideas! how good was the paint job under the silencer?
DODGE the father RAM the daughter!
Old 01-28-2011, 03:21 AM
2011Ram's Avatar
Rep:85
paint job was ok lol. Lots of spray foam sticking out from in between steel layers likely for less tear and silence.
Old 01-28-2011, 07:51 AM
curt4816's Avatar
curt4816 curt4816 is offline
Vehicle: '11 Dodge Ram Crew
Trim Level: Laramie 4X4
Rep:178
curt4816 has a spectacular aura aboutcurt4816 has a spectacular aura about
clean install, nice job!
Mods: H&S Mini Maxx w/ egr and dpf deletes
Old 01-28-2011, 10:00 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Nice clean mod dude. What is that white square on the passenger side? Is that the factory hood light? Mine has the hood light on the drivers side and I have often thought of adding one on the other side. You balanced it out nicely
www.beatcraigslist.com - for posting dangers & secrets
Old 01-29-2011, 07:41 AM
2011Ram's Avatar
Rep:85
That white square is where a factory light would have gone. Basically I'm using the factory cable routing and power source.
Old 01-29-2011, 08:39 AM
2011Ram's Avatar
Rep:85
I`ve given up with the idea of a mercury switch for now. I'm thinking of mounting this illuminated toggle switch at the location in the red oval. In this picture you can see the stock location of the factory underhood light connector. I am toying with using a quick connect plug like the one pictured with a 1in shrink tube to protect the wiring. This is a connector that I have added on my motorcycle for charging or accessory plug in.
That connector is called a large (13mm) Tamiya connector I believe.
Old 01-29-2011, 10:53 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Do you have the factory light? If so, there's a switch included in there (It's a nice robust design too unlike the tiny mercury switch I originally bought!). You'd just have to short the (2) contact points where the stock incandescent bulb normally sits and run your leads to the new lights you just installed.
Old 01-29-2011, 11:14 AM
Ram50Man's Avatar
Ram50Man Ram50Man is offline
Vehicle: 1989 Dodge Ram 50
Trim Level: Standard
Color: Primered Black
Rep:71
Ram50Man will become famous soon enough
I have been thinking of doing something like this as well. Another idea i had.. is to put 3 LED bars under each lip of the my bed so it illuminets the entire bed of my truck. I was thinking with going with a blue, to make the inside of the bed glow. Im also going to throw 3 blue neon lights on the under carriage for some ground effects.
'89 Dodge Ram 50: 2.0L, 5 SPD Manual, 2 WD.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 12:59 AM
LED underhood light mod Barnyard Custom Dodge Ram Interior and Exterior Lighting 11 01-23-2012 06:54 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Audio install w pics.... airbag light :( pankster Custom Dodge Ram Interior Modifications - Custom Audio / Video 8 01-25-2011 12:46 AM
