Old 01-28-2011, 01:27 PM
07QUADCABTN's Avatar
07QUADCABTN 07QUADCABTN is offline
Vehicle: 2007 DODGE RAM
Color: SILVER
07QUADCABTN is on a distinguished road
Default 07 an 08 4.7 hp difference
What make the 75 hp gain difference on the two motors and can you buy yhe parts to make the 07 have the same numbers?
Old 01-28-2011, 01:36 PM
Rep:1845
The heads are the biggest part of the HP gain. Cam profiles remain the same as does bore, stroke and compression.
Old 01-28-2011, 02:30 PM
Color: SILVER
So if I found 08 heads The rest would be the same? Is there an intake change? Or ECM flash needed?
Old 01-28-2011, 02:52 PM
Rep:1845
Without crosschecking part numbers, I can't be sure about the intakes. From the description in the service info, they appear to be the same.
Old 01-28-2011, 03:12 PM
Color: SILVER
Cool thanks for the info..
Old 01-29-2011, 03:18 AM
JLAudio11's Avatar
JLAudio11 JLAudio11 is offline
Vehicle: 2005 Chevy Colorado
JLAudio11 is on a distinguished road
http://www.allpar.com/mopar/47.html
It seems the big differences are the heads and intake manifold. The '08+ are running two spark plugs per cylinder. I'm not sure how involved it would be to run 8 more plugs. I would assume a pcm and various other parts swap.
Old 02-02-2011, 01:12 PM
Color: SILVER
Yeah lot more info there. Ecu tuner here I come.
Old 02-15-2011, 11:50 PM
BMAC BMAC is offline
Vehicle: 2008 Ram 1500
BMAC is on a distinguished road
Ok so after reading your post I went straight to my truck. Where is the second spark plug suppose to be again..... is it under the coil pack???? Because I only could see 4 on each side
Old 02-15-2011, 11:52 PM
Rep:1845
The second plugs are at the end of the wires attached to the coils.
Old 02-16-2011, 10:09 AM
HOLY CRAP that is BAD A$$ Thanks for the picture. thats PIMP
Steering Stabilizers, What a difference ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 21 11-26-2012 09:41 PM
Difference between 4x4 and 4x4OR? pieece Dodge Ram 4x4 - Offroad Discussion 9 11-22-2010 11:34 AM
Difference between the 4.7's khuman Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 7 06-06-2010 02:50 AM
Anyone know the weight difference???? Warwagon 2009 Dodge Ram Forum 1 02-12-2010 10:25 AM
Any difference between 08-09 undercarriage leofiremedic 2009 Dodge Ram Forum 5 10-24-2009 01:41 PM
