Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Old 01-28-2011, 02:25 PM
ramitdamit's Avatar
ramitdamit ramitdamit is offline
Vehicle: 2002 Dodge Ram Quad
Color: Atlantic Blue Pearl
ramitdamit is on a distinguished road
Default Replacing 02 Ram Diff. Bearings 9-1/4 Diff.
Hey not sure if I'm missing something. So far the Axels are out of the diff. within the inside of the diff there were two C brackets which seem to hold the internal assembly in took those off. It's not budgin. I'd really appreciate the help seeing how Chilton's does not give you much on this part.
Old 01-28-2011, 05:33 PM
Resident Technician
Rep:1915
You need a case spreader to get the diff out.
Old 02-04-2011, 05:06 PM
ramitdamit's Avatar
Thanks man. I had to twist what looks like fluid gates into the axel housing to give enough play to yank her out. Now I'm at the stage of putting everything back in. Any tips on gear alignment? From the looks of it everything should just go back in and I will need to twist the fluid gates back out till the meet the bearings.
Old 02-04-2011, 05:14 PM
Resident Technician
Rep:1915
You should check the pinion depth, ring gear runout, bearing preload and backlash. Otherwise you're rolling the dice with the contact pattern. Are you replacing the R&P gears, bearings or both?
Rear diff service ndgo88 4.7L PowerTech V8 Specific Topics 7 04-30-2011 08:50 PM
02 ram front diff. wills360mag 5.9L V8 Specific Topics 4 01-17-2011 04:45 AM
diff fluid change liljohn30 Oil Change 4 10-26-2010 11:36 AM
Where can i buy parts for my 3.92 diff? ThomasRam Suspension 1 11-01-2009 06:05 PM
05 1500 Rear Diff Bearings AaronF Suspension 1 08-25-2009 12:58 AM
