Old 01-28-2011, 04:39 PM
Greillo Greillo is offline
Vehicle: 2002 Dodge Ram 1500 Quad Cab
Greillo is on a distinguished road
Default Steering wheel wooble
Got another one. My steering wheel "wobbles" back and forth consistantly, the faster I go the faster it wobbles, same for slower and slower. It feels like there is a bubble in the tire, but there's not. The truck pulls to the right, always did even shortly after a new alignment and the wobble seems to push that way
I took it to the Dodge Dealer 10 months ago and they said the tires belts slipped and sold me new tires. Never heard of that and I thought the were full of it. It stopped for a while but it started up again about a month ago. The steering does not move violently just back and forth.
Could I need tires so soon or could it be something else?
Any input would be appreciated
Old 01-28-2011, 04:48 PM
BlackBullet's Avatar
BlackBullet BlackBullet is offline
Vehicle: 2010 Ram Hemi TRX4
Trim Level: TRX4
Color: Brilliant Black Met
Rep:39
BlackBullet is on a distinguished road
is it constant? cause it can wobble a little bit when you take it out 4x4
Leveling kit, DSP tuner, 14" MAGNAFLOW with side exit, heavy duty DODGE slush mats, DODGE bed mat,BILLET TECH catch can, STAINLESS steel door sills, K@N drop in filter, level ride airbag suspension....
Old 01-28-2011, 04:52 PM
How many miles on your truck? I suspect you have some worn out bushings in the suspension and your trackbar links (notoriously weak) may have given up.
Old 01-28-2011, 05:05 PM
Thanks. It's constant in any drive. The truck has 140,000 miles
Old 01-28-2011, 05:16 PM
Rep:1845
Steering damper shot?
Old 01-28-2011, 05:23 PM
Not sure but sounds expensive
Old 01-28-2011, 05:29 PM
Rep:1845
Steering dampers aren't nearly as costly as ball joints or a track bar.
Old 01-28-2011, 06:24 PM
HerRam's Avatar
HerRam HerRam is offline
Rep:567
HerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to all
Definately the tires...I had the samething...in my Escape...I had them keep the tire just so I could see...to my eye it looked straight til the guy rolled it across the concrete...it had a wobble to it for sure and wouldn't even stand up on its own.
The way mine happened...I had a low tire didn't realize it (no tpms and I wasn't watching it) and I drove on it too far...hit a pot hole and WHAM tire No good No more.
Friend of mine hit a pot hole and ended up busting a tie rod she too had a wobble in hers...but I would say check under the truck and see if it is the tie rod first...then if nothing...it's definately the tire
http://i307.photobucket.com/albums/nn293/angelgirl3_23/Snowpics008-2.jpg
Mods to my Pavement Pounding Princess :
K&N drop in filter, 'stubby' antenna and
PINK FUZZY DICE!!!
Old 04-27-2011, 06:52 PM
Default a/c problem
my a/c starts cold but gets warm very fast, any suggestions?
Old 04-27-2011, 06:57 PM
Alberto22's Avatar
Alberto22 Alberto22 is offline
Vehicle: 2011 ram 1500 quad cab
Color: Deep water blue Pearl
Rep:72
Alberto22 will become famous soon enough
bent rim. Hid this on my blazer.. took 1000 dollars to find out
The best way to a fisherman's heart is through his fly!
MODS. f1 bakflip, rain guards, Mopar bug deflector, husky floor liners, chrome gas cover, westin side steps,steal craft brush guard,Piaa fog lights, painted calipers, sport hood, KENWOOD EXCELON DNX9980HD with cmos 300 camera, Magnaflow 14"
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 157 09-21-2014 09:47 PM
Center Your Steering Wheel - R&P Steering RamTech Dodge Ram Knowledge Base 4 10-09-2011 01:43 PM
changing clockspring awful knawful Body & Interior 2 05-08-2010 06:27 PM
Steering wheel wobble Mayhem4216 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 04-08-2010 05:50 PM
96 ram 1500 steering wheel jroach1018 Dodge Ram Knowledge Base 0 02-23-2010 01:38 PM
