Old 01-28-2011, 04:21 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Default Catch Can - Worth it?
I can tell you that for a while I have been hearing about catch cans and thought it probably wouldn't make much of a difference on anything. After thinking about it for a while I decided to add a home made catch can to my Ram as a test to see if it would change or help anything. I just bought some hose and used my old air tool filter and rigged it up in between the PCV and the intake as a test. I figured if I liked the results I would go back and do it right. Did it yesterday and took it out today for the first time. Wow what a difference it made to my little 318. After a few hundred miles of driving I can already see a small pool of oil at the bottom of the cup and the motor runs soooo much smoother. When stopped at a light I could barely tell it was running. In case you are wondering my motor is 100% stock. No mods whatsoever aside from this. I was even able to brake the rear wheels loose on dry pavement, from a dead stop and in Drive. I have never been able to do that before. I think I will be adding this to my other vehicles also. The computer seems to have adjusted for the better. So aside from telling my tale I wanted to see if anyone else has noticed any difference before and after the catch can?
www.beatcraigslist.com - for posting dangers & secrets
Old 01-28-2011, 04:38 PM
Rep:1909
I can't speak from a performance standpoint but I can say that the throttle bodies stay a lot cleaner.
Old 01-28-2011, 04:47 PM
HerRam's Avatar
HerRam HerRam is offline
Rep:567
HerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to allHerRam is a name known to all
I have heard all these same things from people with the Hemi motors. they swear by them...I to one day be able to install mine...
http://www.custombilletstore.com/Pro...ductCode=20010
This is where the others were getting their catch cans from
http://i307.photobucket.com/albums/nn293/angelgirl3_23/Snowpics008-2.jpg
Mods to my Pavement Pounding Princess :
K&N drop in filter, 'stubby' antenna and
PINK FUZZY DICE!!!
Old 01-28-2011, 04:59 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Speedlogix carries catchcans too
Old 01-28-2011, 05:05 PM
I've noticed that my TB is a lot cleaner with the catch can on than when it wasn't installed.
Old 01-28-2011, 08:55 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
i talked to a mechanic and he said the oil going into the throttle body is actual seving a purpose. thats why im not gettign one
DODGE the father RAM the daughter!
Old 01-28-2011, 09:26 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Whats that purpose? I run one in both of my Dodge's and don't have an issue.
Old 01-28-2011, 09:32 PM
Rep:55
Yea, I've read the same thing on several threads. That the oil lubricates the seals or seats or something like that. I would think the oil from underneath would do a good enough job at that, and I don't think oil is really supposed to be in the combustion chamber (Randy has more knowledge on that than I would). I think there is a lot of speculation about why it's all done but two things I am pretty certain of: 1-You need crankcase ventilation for the longevity of your engine. A PCV valve is a lot cleaner (no oil spilling all over your engine) and more efficient than an open filter since the air is more regulated and constant. 2-The PCV valve was created to meet government clean air standards and that has little to do with the well being of our engines. I have seen pictures on Mustang forums where they open up their engines more for modifications than we do to our Rams and the oily residue is quite obvious. I was waiting to see if I would get a CEL or something but nope, it ran really smooth. If the oil was so good I don't think it would be running better.
Old 01-28-2011, 09:38 PM
ScatPak07's Avatar
Rep:970
It is a good thing to have since it keeps the motor a little cleaner. You are not sending the crap back into your motor.
Old 01-28-2011, 09:40 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
During the Hemi Engineer chat the Engineer's said the catch-can is a good idea and Mopar will likely be coming out with one.
Brian:
catch can for 07 5.7 brusk Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 32 08-22-2014 01:20 PM
BEWARE whom ever has catch can cold weather mineralram 5.7L (345 cu in) HEMI V8 Specific Topics 17 01-01-2011 08:01 PM
Catch can install? Gron86 2009 Dodge Ram Forum 27 12-07-2010 12:22 PM
Is switching to Royal Purple really worth my time and money? MoparGuy86 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 11 12-16-2009 09:46 PM
2000 ram 3500 4wd.....Whats it worth? bmoparmofo Dodge Ram General Discussion 0 03-12-2009 11:40 PM
