Posi Lock 4x4 engagement system install - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 01-28-2011, 06:39 PM
Leadchunker's Avatar
Leadchunker Leadchunker is offline
Vehicle: 1996 Dodge Ram 1500 4x4,
Color: Green
Rep:57
Leadchunker will become famous soon enough
Default Posi Lock 4x4 engagement system install
I installed the 4x4 Posi Lock system on my 96 Ram 1500 today. Install was easy with some basic tools. The vacuum actuated system is history and the Posi Lock works great. I would recommend this to anyone with a vacuum actuated system, it is very heavy duty and when you engage the 4wd, you know it is in 4wd because you can see the axles and how they function during the install.
Chuck
Lawrenceville, GA.
Old 01-28-2011, 06:53 PM
Good info! Thanks for passing it along.
Old 01-28-2011, 09:06 PM
ScatPak07's Avatar
Rep:970
Yea thanks for letting us know and making the recommendation!
Old 01-28-2011, 09:17 PM
Color: Green
Rep:57
I would post pics but I can't for some reason. I found a really good explanation with photos at http://www.pavementsucks.com/tech-article-29.html
Chuck
Lawrenceville, GA.
Old 01-30-2011, 10:52 PM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
Awesome. The PosiLock system has proven to be a great fix for the vacuum actuated transfer cases.
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 02-08-2011, 11:34 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Looks like it was a fun installation. Well done!
Old 04-01-2011, 10:04 PM
jjklongisland's Avatar
jjklongisland jjklongisland is offline
Vehicle: 2012 Ram 3500 Crew Longhorn
Color: Deep Cherry Red/Tan
Engine: 2011.5-2012 409ci (6.7L) Cummins Turbo Diesel 350hp 800lb/ft
Rep:21
jjklongisland is on a distinguished road
Had a posi lok in my 89 worked awesome... Just make sure you engage it before getting stuck... Dont wait until you are stuck to engage it into 4wd or you will be screwed. The truck needs to move forward slightly while engaging the transfer case in order to mesh the gears...
MOPAR OR NO CAR
Hid install 4 headlight system ssellars Custom Dodge Ram Interior and Exterior Lighting 9 01-18-2011 10:39 PM
Bed lighting / tailgate lock install? rtkman 2010 Dodge Ram Forum 18 12-19-2010 08:25 PM
Security System Self Install (Clifford) DoubleARS Custom Dodge Ram Interior Modifications - Custom Audio / Video 8 11-05-2010 04:17 PM
LOCK PICK Install on Factory REC Nav DECK BIGDROCH Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 04-24-2010 11:42 AM
Bully tailgate lock install query. Dieselkiss Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 5 03-06-2010 12:40 PM
