rear diff capacity - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-08-2012, 12:52 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
Default rear diff capacity
hi all. been doing some searching and haven't found what the capacity is for the 2011 1500 2WD rear diff is. in the paper copy of the owners manual dodge tells you it's 75W-140 but not how much. anyone have that info? thanks.
2011 Ram 1500 Express, RCSB, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Debadged.
2017 Ram 2500 Tradesman, CCSB, Cummins, Blue Streak, MBRP DPF back pipe, K&N drop-in.
Old 07-08-2012, 05:04 PM
RcsbHemi's Avatar
RcsbHemi RcsbHemi is offline
Vehicle: 2010 Ram Rcsb
Trim Level: SLT 4x4 3.92
Color: PDM Metallic Gray
Rep:32
RcsbHemi is on a distinguished road
According to the Amsoil website capacity is 4.6 pints.
Mods: Magnaflow DOD14(resonator removed) line-x, tint, silverstars, tonno pro trifold tonneau, LED Licence plate and reverse bulbs, 2- 27w led fog lights behind grille. more to come........
Old 07-08-2012, 05:48 PM
Rep:2954
If it has a Limited Slip Differential, it also needs a bit of fluid for that
if you have not done it yet, call & request a
BUILD SHEET from Customer Assistance
all they need is your mileage & VIN#
http://www.ramtrucks.com/webselfserv...ucks/index.jsp
Old 07-08-2012, 07:12 PM
Rep:19
double thanks. i had got one. no lsd...yet. i guess dodge does that so we can't change the diff fluid either
Old 07-08-2012, 10:06 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
bottom of the fill hole unless its an American Axle.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
